phelpsa
| posted on 21/3/05 at 09:55 AM |
IRS Installation
Ok, it seems that quite a few people are turning to IRS, and there arent that many plans around, so this thread is where i will post measurements,
difficulties and tips on IRS, and there might even be some drawings if i can get round to it.
This is for installing it into a ready built chassis, and using Stuart Taylor wishbones.
So far:
Get your driveshafts shortened by luego or ST, or any other reputable driveshaft specialist. Do not attempt this yourself unless you consider yourself
a proffesional!
This time last year (that long ago!!) i went and took some measurements of an IRS Stuart Taylor, which was unfortunately crashed at its first
trackday. We took all the vital measurements, ie distance between brackets etc..
TIP #1: If you decide to do the same, write the measurements down in an orderly manor, CLEARLY LABELLED, because when you come to look at them again
in a years time, you will have forgotten which is which.
Then, cut all the lengths of tube to size,
TIP #2: Big Mistake!!! You will forget which ones are for what! Cut them as you need them!
Tack the top half of the box together, before re checking measurements, and then weld it up properly.
Then repeat on the bottom...
Next comes bracketry. Tack first, measure again, weld properly, as usual.
TIP #3: I found that the best way to do this was to get a length of threaded bar, put it through the holes on the brackets, and bolt them on, thus
holding them in place at a set distance apart, and you wont get spatter all over the wishbones. Ill try and get a pick of this.
Next comes welding it in.... Tack first etc....
Theres the first part. I will make some drawings for those of you interested, but that is a simple guide, and should work on any IRS installation.
Donuts
| posted on 21/3/05 at 12:20 PM |
phelpsa,
I am just at the point of thinking on the design of my car, IRS is somthing that i am seriously considering. Any drawings or plans of your setup would
be gratley apretiated.
donuts
Fly Like a mouse, Run Like a cushion, Be the small Bookcase
phelpsa
| posted on 21/3/05 at 12:22 PM |
Unfortunately I have had a bit of a setback
Broken welder
locoboy
| posted on 21/3/05 at 12:50 PM |
Not as bad and more easliy fixed then a broken arm i suppose
Locoboy
ned
| posted on 21/3/05 at 01:26 PM |
Adam,
I know exactly how it feels, i booked a week off work once and the welder packed in on day 2, had to find a load of other litle jobs to do instead,
damn annoying!
Ned.
beware, I've got yellow skin
phelpsa
| posted on 21/3/05 at 01:27 PM |
Its forced me into playing GT4, I swear!!!
