gys
posted on 3/4/05 at 10:48 AM |
Adjustable pedal box
I like the idea of not moving around with weight (~driver) in a car and was wondering if someone has used a (floor mounted) adjustable pedalbox to
cope with differences in driver size?
Perhaps someone has pictures of a mechanism...
Man kann ein Auto nicht wie ein menschliches Wesen behandeln – ein Auto braucht Liebe...
smart51
posted on 3/4/05 at 01:19 PM |
the grinnal scorpion has a movable pedal box because it has fixed seats.
Bike engined cars are slightly rear baised in weight and so sliding the seats forwards will actually help.
Saying that, even a car engined car, with it's slight front bias may be helped by moving the seats as they are so near the rear of the car.
gys
posted on 3/4/05 at 01:55 PM |
It is not for a Seven.
Any idea how they lock the pedals and whether it is easy to adjust them (tools needed?)
Mix
posted on 3/4/05 at 03:10 PM |
CC Cyclone had an adjustable pedal box, try searching for someone who owns/has built one of them.
Mick
posted on 3/4/05 at 03:12 PM |
The system used by Marcos has a threaded rod attached to the pedal box and a fixed point on the bulkhead, the rod is rotated using a control knob
which winds the complete pedal box assembly backwards and forwards. Obviously the brake connections need to be flexible. Also used an extending
steering column from a Triumph G.T.6 .Think they used pendulum type pedals though, H.T.H . Rusty.
NS Dev
posted on 4/4/05 at 08:14 AM |
Plenty of Westfields out there with fixed seats and pedals!
That's what I'm doing. If you don't fit, you cant drive it, simple!
smart51
posted on 4/4/05 at 05:21 PM |
what about putting some seat runners in your foot well and mounting the pedal box on those?
