Avoneer
| posted on 17/4/05 at 09:10 PM |
Chassis update and question?
Chassis coming along nicely and Stuart Taylor engine cradle brackets all in place and tacked up.
Does anyone think the "R" bar will be a problem being 1" inboard of where it should be?
Bearing in mind that the engine cradle offers much additional bracing across the engine bay.
Pat...
Mark Allanson
| posted on 17/4/05 at 09:18 PM |
The 'Readers Digest' engineers will say its all wrong, but fully welded, I doubt you will get any problems. If you are worried, weld a
support ahead of the round section to give an uninterupted load path to the chassis perimeter.
Avoneer
| posted on 17/4/05 at 09:26 PM |
Cheers Mark.
I thought that when it was all welded, it would be fine.
I could always insert a small 3mm plate gusset in-between the round, the top chassis rail on the left and "R"???
Pat...
mangogrooveworkshop
| posted on 17/4/05 at 09:30 PM |
Wouldnt worry Pat the chassis looks great against some ive seen on my travels. Theres one that has enough space behind the seats to store golf
clubs. A small plate will tidy that up...
zilspeed
| posted on 17/4/05 at 10:16 PM |
I wonder what car that would be....
Would it be zetec powered and have rear wheel arches shaped like 50p pieces ?
| posted on 18/4/05 at 11:06 AM |
quote: Originally posted by Avoneer
Pat...
Look at this way you have a 1" offset but room to get the welder nozzle in to do a decent weld. A spaceframe is just a whole load of
comprimises welded together. :-)
ned
| posted on 18/4/05 at 11:08 AM |
i wouldn't worry, think mine is slightly like this. if that worried as said a gusset of 3mm plate should be well sufficicent reinforcement/would
be my line of action.
Ned.
beware, I've got yellow skin
Avoneer
| posted on 18/4/05 at 04:28 PM |
Will gusset then - being a lightweight BEC though, I'll drill some holes in it!
Pat...
Avoneer
| posted on 2/5/05 at 09:48 PM |
Made a gusset and then decided this would be better (the small round bar is at right angles to the engine cradle mount).
This should be ok shouldn't it???
Mark Allanson
| posted on 2/5/05 at 10:18 PM |
The addition of a tiny gusset would make it spot on
Avoneer
| posted on 2/5/05 at 11:09 PM |
Ah.....
Mark - you are the font of all knowledge for stuff like this - thanks.
Will stick a small gusset where indicated.
I got a bit confused, was gonna put the gusset in the triangle between the small round bar I added, the top outside chassis bar and the top chassis
bar that has the engine cradle mounts on it.
All makes sense now.
Pat...
Avoneer
| posted on 3/5/05 at 09:28 PM |
Got it....
