Clay
posted on 5/5/05 at 01:58 AM |
Some questions (Control Arms, Shifter Arm, Hub)
I am new to locost building, but i am a Mechanical Engineering student with a basic education in chassis engineering. I've read Tune to win, and
Engineer to win by Carroll Smith, Chassis Engineering by Herb Adams, and Build your own sports car 2nd edition by Ron Champion.
Here are some questions:
When using double wishbone A-arms can you make them un-cemetrical? Like, can one arm of the A-arm be longer than the other, or be at an offset angle?
For packaging purposes?
Also, can some of you post your fixes for remote shifters? Ive seen a couple but would like to see some other fixes for shifter placement.
What spindles/hubs do the americans use since we dont have cortinas(spelling?) available?
And lastly, those of you who have photos of the progress of their build, can you please post them? Ive seen one or two photo diaries of their locost
builds, but you can never see enough.
thanks
Clay Marsh
want2race
posted on 5/5/05 at 02:38 AM |
Firstly the fact you have a degree in that and dont know the answers leaves me fearing American engineering!
Secondly your options are limitless. go to yahoogroups and look for locost there is a massive listing of posts by various people.. all your answers
are there!
www.want2race.net/lotus7/building
[Edited on 5/5/05 by want2race]
kb58
posted on 5/5/05 at 05:22 AM |
You need to read a few more books! Check out my list, here: http://www.kimini.com/Reference/index.html
If none other, read Staniforth's "Competition Car Suspension"
Also check out my site and other's for build pictures. I have a few remote shifter pictures buried in there somewhere... just go back a few
years.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Clay
posted on 5/5/05 at 06:19 AM |
I am a second year college engineering student. So that means I havent started any classes directly related to my major yet. American Engineering
doesnt have a problem, i just havent gotten into the core of my education yet. The education in chassis engineering i mentioned is from reading
chassis engineering books, not from school. But either way, I dont and wont have any classes that discuss control arm design or popular kit car
spindles.
years.
kb58, thank you! im always excited about reading new books on chassis engineering and furthering my knowledge. Ive recently purchased a "How to
build hot rod chassis" book that arrives tomorrow, It may help with some explanation. ill check out your reccomendations also, i appreciate your
advice and pictures.
[Edited on 5/5/05 by Clay]
Clay Marsh
Clay
posted on 5/5/05 at 08:30 AM |
want2race, i saw the picture of the miata, was that the donor car you used? Are the spindles/hubs on your locost from the miata?
Clay Marsh
chrisf
posted on 5/5/05 at 09:55 AM |
Unequal length A arms are used quite a bit. The lower arm will be the longer. This is well described in 'Tune to Win.'
I might be a bit biased, but the Miata is the best of the US donors. Quite a few people use them and you may not have to design anything at all. It
may be done for you!
Have a look at my website for a build diary. I'm using Miata bits and a bike engine.
--HTH, Chris
James
posted on 5/5/05 at 10:31 AM |
thanks
Hi Clay,
Welcome to the site.
The arms of a wishbone can be different lengths- I pretty sure I've seen Formula 1 cars with different length arms.
As for build progress: have a look through the photo archives here. Loads of people have comprehensie archives.
Hope that helps,
James
- Muhammad Ali
Alan B
posted on 5/5/05 at 12:00 PM |
Hey Clay...where in Florida?
We could be neighbors.....
Also check out my site too...click www below....
Alan
NS Dev
posted on 5/5/05 at 01:18 PM |
welcome, for a start!
suspension arms can be pretty much any shape, size or anything else.
As long as you remember the basic engineering that you are learning now, and apply it, then you have no problem.
Certainly unequal length top and bottom A-arms are critical to handling characteristics, all the locosts on here have unequal length arms, those using
sierra uprights perhaps too much so!
Obviously, a shorter upper arm will pull the "top" of the wheel in during roll, and induce more negative camber, thus compensating for the
tyres rolling over on the rim during cornering.
the arms can also be angled convergent or divergent relative to each other, and this then affects the roll centre, which in turn dramatically affects
the handling (roll centre vs COG)
The arms can then also be angled fore and aft, which then brings in many complex equations regarding castor angle change in roll, some of which I have
incorporated into the skewed suspension setup on my short oval grasstracker, but won't go into the complications of now!
Clay
posted on 5/5/05 at 06:03 PM |
I apologize, I should have made my question more clear. I am fully aware of the effects of unequal length A arms and changing their angles. My
question was about the shape of each arm. A symetric A-Arm would be an isosceles triangle, with both legs of the arm being the same length. Ive seen
some people that have odd shaped control arms. They are still shaped like an A but each leg is a different length to fit under a shell or fit around a
mid engine, etc. I was wondering if changing the shape from an isosceles triangle had any adverse effects. My line of thought is that as long as it
follows the same arc of travel, it should be fine. but i was looking for some assurance.
Alan
Hey Alan, Im in Orlando, how bout you? Thanks for the welcome.
--HTH, Chris
I was also thinking the same thing about the miata being golden in this type of project after seeing some pictures. thanks for the link to your build
diary, im sure ill be posting some questions for you shortly.
Thanks everyone for the friendly welcomes, im sure this will become more of an unhealthy obsession as my knowledge builds from the help of you all :-)
Clay Marsh
clbarclay
posted on 5/5/05 at 06:23 PM |
I shouldn't think wishbones not being isosceles makes any difference.
I would guess that the majority of wishbones are not isosceles, the only example of isosceles wishbones I can think of is locost lower wishbones
(mabye seen one or two others but can't remeder them at the moment), the top locost ones are not isosceles
[Edited on 5/5/05 by clbarclay]
Clay
posted on 5/5/05 at 11:28 PM |
want2race
want2race, did you have to alter the location of your shifter or did it line up to a decent location in relation to your body sitting in the car?
Clay Marsh
want2race
posted on 6/5/05 at 02:23 AM |
Hit me up on AIM.
my sn is eyedhitit
I moved the engine back till I got what I wanted! And my chassis is EXACTLY what I wanted in all cases No exceptions just solutions~
