kevin booth
posted on 7/5/05 at 07:34 AM |
chassis
what is wrong with the book.
omega 24 v6
posted on 7/5/05 at 09:39 AM |
its a bit vague in most areas but for chassis plans try the mc sorely web site as posted many times here before. Everything you need here for chassis
building.
James
posted on 7/5/05 at 11:13 AM |
What, apart from the title and the content?
Nothing!
James
P.S. This has been covered loads, just have a look though the past few weeks posts. But start by getting an accurate chassis plan from:
http://www.mcsorley.net
- Muhammad Ali
paulf
posted on 7/5/05 at 02:42 PM |
The biggest problem is the fact that the wishbones are incorrect, so the castor angle is difficult to achieve without positioning the brackets in thin
air.The top one needs at least an extra 10mm of offset.
The other dimensions are a bit variable but if you cut and fit each tube as you go then there is no problem making it all fit.
Paul
Nothing!
James
clbarclay
posted on 8/5/05 at 12:47 PM |
The dimensions for trailing arm brackets are not consistent. the book gives 2 dimensions. Depending on what dimension you chose to use it alters the
nominal height of the rear axle.
