New Topic New Reply
Author: Subject: Main upper column mount positioning
Avoneer
posted on 9/7/05 at 04:49 PM Reply With Quote
Anyone any tips on mounting/making a bracket for the top part of the Sierra column to mount it to the chassis and how to work out how high and how far from the pedals?
Also, don't know whether to have the traingular end of the column going under the chassis bar (near the pedals) and through the footwell end (like MK) or whether to go over the chassis bar like Stuart Taylor.
Anyone any tips/experience?
Thanks,
Pat...
clbarclay
posted on 9/7/05 at 05:06 PM Reply With Quote
I made judged column position by what felt right when sat in the car (fixed seats in first).
I went for column over chassis rails because it fouled my feet (size 10.5) with boots it it went under. The angle also seems more nartural to me.
I postioned the column where it wanted to be and then made the brakets to fit it.
The Brakets are made from 3mm plate and 50*50*3mm angle iron trimend and shaped to fit. The braket for the bearing has a 3mm thick ring welded to the other side so the sierra bush is a better fit.
The 2 over long bars will be shorted and then weled in place to support the main braket so when some fool pulls up/down on the steering wheel it shound not twist the chassis rails.
Its currently a work in progress, waiting to be fully welded. Rescued attachment DSCF0028 small.JPG
posted on 9/7/05 at 06:15 PM Reply With Quote
mine is not book, but VERY similar to mr barclays
mangogrooveworkshop
posted on 9/7/05 at 06:55 PM Reply With Quote
If you go too high you run into the space problem for the altenator on a CEC
indykid
posted on 9/7/05 at 07:52 PM Reply With Quote
its alright, it's bec, though i don't know what it will foul on with the blade engine in.
mk put all their columns through the top of the footwell, like mine, regardless of engine.
looks neater imho, especially with floor mounted pedals, as it takes all the bulk out of the firewall, and just looks smoother.
tom
smart51
posted on 9/7/05 at 08:21 PM Reply With Quote
the column on my MNR goes over the chassis. It makes the wheel almost vertical but does free up the foot well.
When fitting mine, I but in the drivers seat and adjusted it to suit the fixed pedals (brake and clutch). I set the steering wheel and acccelerator pedal to where they felt comfortable. You could cable tie the column in place to see if it's right.
[Edited on 9-7-2005 by smart51]
Avoneer
posted on 9/7/05 at 08:43 PM Reply With Quote
One of the problems is the top mount - I have nothing to cable tie it to yet.
Got to work out how far back the top mount goes from the bottom one - but I guess once I have the bottom one sorted, the top one will be easier.
Tom, when can I be nosey at your car again and take some measurements?
Pat...
clbarclay
posted on 9/7/05 at 08:48 PM Reply With Quote
tom
The MK chassis is 1 inch taller IIRC?, giving more space to avoid your feet if the column goes under the chassis rail.
One way of supporting the top of the column (once the bottom mount is fixed) is to place a broom handle/length of wood on top of the chassis rails with the column rested on top. You will want the column shroud on to keep the column stable though.
[Edited on 9/7/05 by clbarclay]
New Topic New Reply
