Danozeman
| posted on 11/8/05 at 05:16 PM |
Pipe advice needed please.
Probably the wrong place but as its chassis, fuel, suspension i dint know where to put it.
What do you chaps think of the clearance for the fuel feed? I plan on running rubber hose from the outlet along the chassis rail to the pump which
will be mounted infront of the axle on the crossmember.
I know the axle shouldnt mover far but im concerned about the clearand between the panhard rod and the outlet.
  Pipe clearance?
  Pipe clearance 2
[Edited on 11/8/05 by Danozeman]
Dan
chrisf
| posted on 11/8/05 at 06:15 PM |
Shouldn't the tank be flipped around so the feed is in the rear? This way, there is less of a starvation issue under braking.
--Chris
Danozeman
| posted on 11/8/05 at 09:38 PM |
Why would there be a starvation issue under braking?? surely the fuel will slop forwards?
Am i missing something obvious and being exceptionaly dim? Tell me if i am.
Dan
| posted on 11/8/05 at 09:44 PM |
I don't think you're missing anything, the fuel would indeed slop forwards under braking.
| posted on 11/8/05 at 10:04 PM |
mayeb he meant acceleration. i dont have a clue myself, but would recommend just keeping it full anyway
NS Dev
| posted on 12/8/05 at 07:15 AM |
that looks a touch closer than I would like if its going to be just a rubber pipe bend coming off that.
You could make a 90 deg bend in steel or copper pipe, and join it with a rubber stub (and pipe clip obviously!!) to the tank outlet, then put the main
pipe onto that. Then you have no worries about it moving over time and chafing on the panhard rod.
That's what I'd do anyway.
| posted on 12/8/05 at 10:21 AM |
I'd be tempted to cut half of that off, it's rather long. If it's lower than the panhard rod you shouldn't have a problem with
it.
chrisf
| posted on 12/8/05 at 01:25 PM |
Ah, yep, I meant acceleration I'm putting my feed to the rear of the car. Pete has a good idea, though. If you are going to keep the cell in
the current orientation, you could chop a bit off.
Still, I would turn the cell so the feed is in the rear....
| posted on 12/8/05 at 04:17 PM |
Ever see how close the handbrake cable run to fuel tank on an MGB ;-)
Danozeman
| posted on 12/8/05 at 04:47 PM |
Thanks lads. I think ill chop it a bit and see what happens. The rubber pipe wil be clamped down so should go anywhere.
Dan
