drmike54
| posted on 22/8/05 at 01:14 AM |
Finally Started My Chassis Build.
I have the bottom of the frame tack welded so far. Are most of ou just welding the horizontal surface or the horizontal & Vertical surfaces. I
tryed moving the chassis and it will flex like a wet noodle. Shoud I put a tack on the vertical surface too?
Started this with my 11 year old son on my 51st birthday
[Edited on 22/8/05 by drmike54]
Started Welding the chassis!!!!
Avoneer
| posted on 22/8/05 at 07:39 AM |
I put a little tack on every join I could.
It's a great buzz when you get going and the enthusiasm lasts a few weeks and you get a load done - then it all gets a bit hard!
Good luck, looks good so far!
Are you using the McSorley plans?
Pat...
Russ-Turner
| posted on 22/8/05 at 10:26 AM |
He, he... *rubs hands* my turn Wednesday :-)
