New Topic New Reply
Author: Subject: Track Width
caber
posted on 27/8/05 at 09:30 AM Reply With Quote
Track Width
It seems pretty inevitable that I will end up with a back axel wider than the escort type whether it is a Sierra or something else. If I use a book chassis the front track will be narrower than the back track is this a problem?
I have not seen any design that has longer wishbones is it possible to lengthen these or is it sensible as I have seen some incidents of bent standard length lower wishbones on the forum.
If I understand the McSorely drawings his +4 chassis makes the whole length of the car 4" wider. As I am not keen on doing my own fibreglass is there any available fiberglass to fit the +4 chassis?
TIA
Caber
posted on 27/8/05 at 11:10 AM Reply With Quote
Buy the font wishbones in -- the book design isn't good and making the wishbone is a very time consuming part of the build most of the (reoputeable) Locost parts suppliers do wide track wishbones for the Sierra front end.
Volvorsport
posted on 27/8/05 at 11:13 AM Reply With Quote
make the front part of the chassis 4 inch wider at the bottom as i have done , my wishbones arent as wide , ill be offering some wishbones shortly .
www.dbsmotorsport.co.uk
getting dirty under a bus
James
posted on 27/8/05 at 11:49 AM Reply With Quote
You've made the bottom of the chassis 4" wider? But not the top?
What effect does that have on the wishbone mounts?
James
quattromike
posted on 27/8/05 at 12:25 PM Reply With Quote
That must really alter your suspension geometry and inevitably alter the handling characteristics of you car does it not?
Volvorsport
mounts are ok , wishbone is a tiny bit longer , but geometry is still good , im using the original strut tho as the upright - as far as i can tell tho , the upright ball joint position isnt to far away from a sierra based one . so really its only the bottom wishbone thats lots different .
if you come to brands hatch on sept 17th , youll see !!
New Topic New Reply
