Avoneer
| posted on 30/8/05 at 09:11 PM |
Front light bracket
Of the various ways of doing the front light brackets, how does this look?
I know the light isn't quite straight before anyone mentions it.
Yes, it will be at the right high for SVA.
Piece of flat bar under the ali trim which supports the light. The ali plate will be carbon fibre when finished and cover all the sharp edges and has
a nicely rounded front edge and side on it.
Kind of Stuart Taylor-ish but on a bigger scale.
I think it looks "tidy".
Any thoughts?
Pat...
Northy
| posted on 30/8/05 at 09:24 PM |
I think it looks ugly
Sorry
Graham
Surrey Dave
| posted on 30/8/05 at 09:37 PM |
I prefer mine!!
Once the threads are cut off..........
Triton
| posted on 30/8/05 at 09:40 PM |
argh...too much like RH.....do it like the picture i posted Pat.....two bits of oval tube(one each side) cut at 95mm long with 10 degree cut one end
weld it to chassis then on the end use 2" diameter tube with a big penny washer welded on top to mount your light.....job's a good un
Triton
| posted on 30/8/05 at 09:41 PM |
Pat, are you welsh by any chance?......."tidy"
Avoneer
| posted on 30/8/05 at 09:48 PM |
Welsh!
No, Salfordian come Yorkshireman in the last few years.
So no one likes it then?
I do like your idea Triton, but I like mine as well.
Going to look at some Robins now...
Hmmmm...
Pat...
Danozeman
| posted on 30/8/05 at 09:52 PM |
Dont mean to nick this thread but can ppl post some picies of how theyv mounted there headlights please??
Dan
Triton
| posted on 30/8/05 at 09:56 PM |
Here you go
Triton
| posted on 30/8/05 at 09:57 PM |
"Theres tidy" ......as they say in wales
Avoneer
Just about to post that pic for you.
Just going to get a pic in the garage of my other idea.
Watch this space.
Pat...
Avoneer
| posted on 30/8/05 at 10:07 PM |
Ok,
Other solution.
I can utilise the round top front chassis tube to house the headlight bracket "arms" as my shock bracket would get in the way if I did it
the same way as Triton's.
Pat...
Avoneer
| posted on 30/8/05 at 10:08 PM |
And another angle:
Triton
| posted on 30/8/05 at 10:34 PM |
Tickety boo that is
Simon
| posted on 30/8/05 at 10:39 PM |
Fits into "honeycomb?" glassfibre and ally tube with locking bolt through.
Simon
scutter
| posted on 31/8/05 at 06:33 AM |
Here you go, I've increased to height a little now to clear the cycle wings.
  headlamp trail 02
ATB Dan.
Ian Pearson
| posted on 31/8/05 at 08:30 AM |
I used the mounting brackets off a 2CV.
