RoadkillUK
posted on 11/9/05 at 03:57 PM |
How should I fix this?
OK, so I lost the back end, mounted a kerb and hit a wall.
The chassis has taken a little damage, the wishbone bracket (lower rear) on the front has moved in, twisting the chassis rail.
Photo's below show the damage, which in my opinion isn't too bad.
I think that I should remove the bracket, attempt to twist it back, plate over the top of the 2 rails and then put another bracket on.
My brother reckons we should cut out the effected rail(s) and replace.
What do you think We should do?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Chris_R
posted on 11/9/05 at 04:30 PM |
If it were me I'd want to replace the twisted tube, but that's because it would bug me if I just repaired it.
I also notice that someones hand is trapped between your axel stand and the chassis. Just thought I'd say.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
posted on 11/9/05 at 04:51 PM |
Start by taking the engine out -- no matter what way you try and repair it you will need to have the engine out for access and so you can check
everything is "square".
While I am pretty sure it can be repaired without replacing the chassis members by careful use of hydraulic ram and localised use of oxy-acetelene
heat as chris_R says would you ever be truly happy with it ?
If it were mine I would probably cut the outer tube out and straighten the inner onewith local heat and jacking with clamping it ot to a build
board/jig the weld in a new outer tube
ned
posted on 11/9/05 at 06:35 PM |
i'd cut the outer tube out and replace it, leave the inner tube in situ and weld a bit of 3mm plate over the top. all imho
Ned.
beware, I've got yellow skin
Is that the one you were doing yesterday?
UncleFista
posted on 11/9/05 at 07:15 PM |
Yes, it was running so sweetly he decided to stack it.
Just... gotta... keep... mouth... shut......
Tony Bond / UncleFista
lexi
posted on 11/9/05 at 08:16 PM |
I just think it`s amazin how strong that cruddy welding is. Was it mentioned at SVA?
Alex
Avoneer
posted on 11/9/05 at 08:35 PM |
What a lovely compliment!!!
That crap they all broke with the impact???
You should see some of mine - but they've all got plenty of penetration and don't want to separate with a hammer or hacksaw.
Pat...
[Edited on 11/9/05 by Avoneer]
Cita
posted on 11/9/05 at 08:36 PM |
Is it my eyes or is that inner tube not welded to the crossmember and upright tube?
As said earlier you have to take the engine out.
I would say replace at least the outer tube.
It will cost you close to nothing in material,just a lot of work but you would feel safe.
Cita.
UncleFista
posted on 11/9/05 at 09:12 PM |
Alex
Not a word, but then he was more interested in strength than beauty.
The only "cruddy" weld is a weak one IMHO
RoadkillUK
posted on 11/9/05 at 09:46 PM |
My welding isn't the best but after the impact, I'm quite impressed. I was expecting much more damage than what there is.
Cita, that bar is most definately welded
Alex, you see how the tube twisted and the weld didn't break, that's a good weld that is
Roadkill - Lee
www.bradford7.co.uk
posted on 11/9/05 at 10:57 PM |
How to make friends and influence people .
I've seen worse on a lot more expensive cars. Cut the bent rail out from under the fu tube and replace as much of it as you can along with the
bracket for the wishbone.
Jon Ison
posted on 11/9/05 at 11:03 PM |
agree on the welding, saw much worse on a stand at Harrogate, no names as its just IMHO........
but i know one or two others remarked upon it, you take your best tackle too a show don't you ?
As for the repair, id'e replace the tube, infact iv'e got a few too do, wanna give us a hand ?
RoadkillUK
posted on 12/9/05 at 12:28 AM |
Thanks all for the advise. I think it's time to take it off the road and strip it down for the winter clean up.
Roadkill - Lee
www.bradford7.co.uk
posted on 12/9/05 at 10:17 AM |
A bit OT, but I was justing thinking that the chassis finish is very good for a 'used' car. Is it powder coated? If not, what paint is
it?
Also what paint did you use on the 'bones so I can avoid it!
Avoneer
posted on 12/9/05 at 11:08 AM |
Jon,
If you need a hand for a few hours, I don't mind chopping some tubes and tacking them in place for a pint!
Pat...
posted on 12/9/05 at 12:35 PM |
Have you got the all clear from the insurance Jon? I saw Bryn in the week and he didn't know you'd had an off.
lexi
posted on 12/9/05 at 04:26 PM |
Exactly mate and congrats to you. SVA proof and kerb proof.
Alex
[Edited on 12/9/05 by lexi]
RoadkillUK
posted on 12/9/05 at 06:13 PM |
Thanks for the offer Pat, although I'm sure we can manage
The chassis is powdercoated (for now) and I can't remember what paint I used for the bones but I didn't prepare them properly anyway, rush
job as they were replacements.
[Edited on 12/9/05 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
Rorty
posted on 13/9/05 at 03:45 AM |
I would cut out anything that remotely looks like it's moved and replace it. I'd also check the accuracy of the wishbones and
renew/replace as necessary.
As for the "cruddy" welding (and by Christ it is!), it may have held up til now, but your excursion may have been the last straw. I would
grind it all out and if you're welding hasn't improved, I'd get someone in who can weld. No offence meant, just being realistic.
Cheers, Rorty.
