quattromike
| posted on 23/9/05 at 09:50 PM |
Rear Diff Suports?
I'm currently working on the rear of my chassis, having fitted the rear A-arms of my irs I'm about ready for trianglation but, I also need
to fix up my diff, it came from a 2wd sierra cossie and is quite heavy as I'm sure you're aware but how stiffly do I need to build it into
my chasis?
Do I need to fix it through every hole on it or do I get away with only fix it at the front and on the back?
I've had a little think about it and there would be alot of twisting on it would there from the propshaft coming from the gearbox and thedrive
shafts wanting to turn and the wheels not.
I want it to be substantial but not overkill
Mike
| posted on 23/9/05 at 09:58 PM |
most manufacture's cars use the two bolts at the front, and none at the back. Seems adequate. Triangulate it as best you can, as it does
experience a fair bit of torque reaction
locoboy
| posted on 24/9/05 at 08:33 AM |
I have heard good reports about the mounting plate from GTS Tuning, and it looks to me like it would do the job perfectly well.
Click Here
19.95 per pair + P&P
Locoboy
Mix
| posted on 24/9/05 at 09:54 AM |
I'm leaning towards using the rear mount aswell and using the diff case as a form of triangulation.
Mick
quattromike
| posted on 24/9/05 at 12:41 PM |
Click Here
yeah I couldn't see any pics of the gts ones, but I'm going to have a go any way an see what happens 3mm should be ok if i fit some
stiffners in too.
Anyone got any pics of their suport brackets they could show?
cheers
Mike
[Edited on 24/9/05 by quattromike]
quattromike
| posted on 24/9/05 at 04:19 PM |
Damned it I had to go to work had a break down so never got it done it'll have to be tomorrow now.
Got some more bits from work tho
Like I say it's not what you make it's what you take home
Mike
Simon
| posted on 24/9/05 at 07:25 PM |
I used 3mm plate cut to a similar shape to those used on the Sieera cross member.
Also used the rear mount, but not the front lower one.
Simon
Gav
| posted on 24/9/05 at 07:40 PM |
ive got a pair of these on order from GTS, ill post some pics when done.
andyace
| posted on 25/9/05 at 08:05 AM |
stiffners in too.
cheers
Mike
I will put a pgoto of them fitted to my GTS chassis today 4 U , in the mean time you can just make them out in the GTS Chassis 2 pic on my archive
(200509 folder)
[Edited on 25/9/05 by andyace]
| posted on 25/9/05 at 09:41 AM |
its an easy solution, but i suspect it could be done cheaper and lighter at home just by using some 3x25mm strips, and designing the chassis around
it. I intend to incorporate a simple rectangle into the end of my transmission tunnel, 7" wide inside and about 8-10 tall, sloping back at about
14 degrees. (i think 14 degrees is correct, if anyone knows better, feel free to chirp up!). Then i'll just hang some lugs off it, as short as
possible, and bolt it up tight.
Mix
| posted on 25/9/05 at 03:14 PM |
I made mine from 3mm plate, took about an hour.
DIY and use the cash for something you can't do yourself.
Mick
907
| posted on 25/9/05 at 03:54 PM |
Yup. I'm with you Mick.
I have put an angled bracket on the back.
It seemed a good place to brace the bottom of the "boot box thingy" that I plan to make.
Paul G
quattromike
| posted on 25/9/05 at 11:26 PM |
thanks Mick and Paul. Looks like what i was thinking, I'l have a slightly different shape because my chasis is a bit different but it'll
be along those lines. I'll get done a bit and post some pics to let you all see
Mike
Bob C
| posted on 26/9/05 at 04:27 PM |
Here's another approach - I wanted mine mounted on rubber so I stuck on some suspension bushes.
Bob
