joolsmi16
| posted on 3/10/05 at 06:25 PM |
front suspension doubts
Hi all, I have a worry about my front suspension setup on my current build it seems that the top wishbone sits at a step angle when the bottom
wishbone is level to the ground??
Is this accpetable or will I need to reposition the top wishbone "U" brackets?
I have quickly read through the "suspension and brakes" book and reposition the setup to obtain the top balljoint to sit 25.5/38mm higher
than the top "U" bracket, and the centre of the lower wishbone balljoint to be 6.3-16mm lower than its "U" bracket.
Can anyone advise on if any of the above is correct or will I need to start repositioning brackets ect,??
Thanks for any advise.
joolsmi16
| posted on 3/10/05 at 06:38 PM |
Right as rain thats how the front roll centre height is fixed.
Normally at running ride height the the inner pivot of the lower wishbone should be slightly higher than the lower ball joint.
Avoneer
| posted on 3/10/05 at 08:30 PM |
That's spot on.
Although it looks "wrong" if, they were both parallel, when you go over a bump, the camber wouldn't change, like it does the way you
have it.
Pat...
Mark Allanson
| posted on 3/10/05 at 09:27 PM |
Remember, the lower wishbone is parallel when the ball of the balljoint is at the same height as the centreline of the inner bush bolt. Not when the
wishbone tube is parallel
| posted on 3/10/05 at 10:37 PM |
Screw the top balljoint in as well, you look to have positive camber there although it's hard to see from the angle of the picture.
NS Dev
| posted on 7/10/05 at 12:45 PM |
quote: Originally posted by Avoneer
That's spot on.
have it.
Pat...
nit picking now, as what you are saying is quite true apart from the reasoning! The wishbones can be parallel and still pull on negative camber in
roll, this camber change is derived from the difference in lengths of the top and bottom wishbones, not their angles. The shorter wishbone will move
in a tighter arc thus pulling in the upper balljoint as the suspension moves up or down from it's neutral point.
