New Topic New Reply
Author: Subject: how much does it weigh
Messenjah
posted on 5/10/05 at 10:22 PM Reply With Quote
a bare chassis anyone weighed one
locost or other like mk indy, mnr, luego , rh, iger,mac#1, ....
andylancaster3000
posted on 5/10/05 at 10:25 PM Reply With Quote
At this stage here...
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=DSCF0072.JPG
....it weighed 45.5Kg. (without nose) Don't believe the 35lbs as claimed in book!Sorry, can't help you for a completed chassis weight.
HTH
(normal book chassis)
[Edited on 5/10/05 by andylancaster3000]
flak monkey
posted on 6/10/05 at 08:21 AM Reply With Quote
I did a CAD model and worked out th weight that way.
Think the result was something like 85-110Kg, depending on the amount of steel or aluminium panelling you used.
Sera
http://www.motosera.com
cymtriks
posted on 6/10/05 at 02:45 PM Reply With Quote
My FEA gave a weight estimate as part of the output.
184 lbs / 84 kg with all welded in 16g panels.
The aluminium panels are not included in this total, it's for the welded steel structure only.
SkinnyG
posted on 6/10/05 at 03:02 PM Reply With Quote
My "book" build with Aussie mods, a few extra diagonals in the engine, tranny and engine crossmember, plus a four-point roll bar (1.75 .093 ERW) with removeable Petty Bar, all mounts and brackets and 22ga sheet steel welded in at the rear quarters and bottom of the nose weighed 200lbs, according to my bathroom scale.
I have five bathroom scales to check for accuracy.
Greg
www.gwellwood.com
Stu16v
posted on 7/10/05 at 05:58 PM Reply With Quote
A bit of a fetish?
MikeR
posted on 7/10/05 at 10:51 PM Reply With Quote
i've got 9 - and only one is in the bathroom!
when i finally finish the car i'll have my very own flatfloor.
New Topic New Reply
