New Topic New Reply
Author: Subject: wooden panels
spitfire
posted on 2/11/05 at 08:44 PM Reply With Quote
wooden panels
hi i have got a 7locost with a purpose made chassis with the old cortina front suspension thats how old it is.I have got the old bench seats in the car and i am strugling fitting the 3 point harness the top one will fit on the roll cage but do the two bottom ones need to go to the chassis for the sva (how do i add photos to my profile ) Thanks
[Edited on 2/11/05 by spitfire]
ReMan
posted on 2/11/05 at 09:02 PM Reply With Quote
Yes?
So whats the wooden panels then?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
spitfire
posted on 2/11/05 at 09:12 PM Reply With Quote
floor and side panels
Danozeman
The bottom ones need to go on the chassis either with triangle welded on or threaded tubes.
Wheres the wood? OOOps too slow.
wooden floor? Is it a locust?
[Edited on 2/11/05 by Danozeman]
Dan
spitfire
posted on 2/11/05 at 09:38 PM Reply With Quote
hope it is the chassis was made by a kit car company and the called it a locost .i thought all the old locost had a marine plywood body tub ?covered with alloy body it that wright?
posted on 2/11/05 at 09:41 PM Reply With Quote
Locost is metal spaceframe, scratchbulit to ron champions plans, locust is wooden frame significant difference there.
[Edited on 2/11/05 by JoelP]
spitfire
posted on 2/11/05 at 09:51 PM Reply With Quote
hi i have got the locust not the locost sorry my fault
Lightning
posted on 2/11/05 at 10:16 PM Reply With Quote
Yes its a Locust and the outside bottom seat belt mounts are a problem as there is no chassis there. You had best phone up the SVA station to see whether they would allow spreader steel plates under the floor. I somewhat doubt it. You may have to weld some steelwork back to the chassis underneath,which could also be a problem if the tub is perminantly fixed.
I had one some years ago but got it through on an MOT 1 week before SVA's for that very reason.
kipper
posted on 2/11/05 at 10:44 PM Reply With Quote
wooden panels
Try the locust club site on
www.locustenthusiastsclub.fsnet.co.uk
They are a friendly bunch and I am sure they will help.
Regards Kipper.
spitfire
posted on 4/11/05 at 09:44 PM Reply With Quote
thanks for all your help
New Topic New Reply
