drmike54
| posted on 15/11/05 at 04:01 PM |
Wide Rack and Longer Brackets?
Here is my idea to deal with a wider rack. use brackets made out of 2" x 2" HREW that are longer to extend the chassis width. 3 1/2"
Tall brackets.
Started Welding the chassis!!!!
drmike54
| posted on 15/11/05 at 04:03 PM |
Bracket Picture.
| posted on 15/11/05 at 04:32 PM |
Would this be used in conjunction with shorter wishbones (which will change suspension geometry), or would you be using standard wishbones and having
a 7" wider track (which would be a very wide locost).
I would also want to make sure that the extra torsional stress that will be applied to the frame tubes is going to be ok.
