New Topic New Reply
Author: Subject: Chassis update
Avoneer
posted on 19/11/05 at 10:19 PM Reply With Quote
Chassis update
How am I looking???
Not far off the powder coaters now.
Pat...
Avoneer
posted on 19/11/05 at 10:20 PM Reply With Quote
Ooops, forgot the pic:
Chippy
posted on 19/11/05 at 11:45 PM Reply With Quote
That's one wicked roll cage you have there, put some casters on it and you could run either way up.
dl_peabody
posted on 20/11/05 at 06:25 AM Reply With Quote
Are you going "media blast" that surface rust off before you powder coat it?
wilkingj
posted on 20/11/05 at 12:23 PM Reply With Quote
Is that a new process where you plaster TV images all over the chassis before painting?.
Joking apart... Have it shot / sand blasted FIRST. Its worth the money, as a poorly prepared surface will cause the Power costing to peel off. ie you will waste your money.. Easier to do it right at this stage.
I have had this happen. Where the metal was filed / ground / sanded (welds etc) the power coating has stuck like Sh*t to a blanket.
Its false economy not to blast it.
Best Regards
Geoff
http://www.v8viento.co.uk
Avoneer
posted on 20/11/05 at 03:32 PM Reply With Quote
Sorry, it will be blasted before powder coating.
Pat...
dl_peabody
posted on 24/11/05 at 05:23 AM Reply With Quote
Some places use little plastic BB's instead of sand. Recycleable and easier to clean.
I want a TV in my Garage so everything will be media blasted....TV...Couch.....Refirgerator....if I can find a spare PC that too.
New Topic New Reply
