jk
| posted on 8/12/05 at 03:16 PM |
MK indy wide?
Anyone know if they can/would do a slightly more accomodating chassis? (just not quite as girthy as a viento)
Bearing in mind i'd like IRS sierra rear end, pref + LSD and disks.
TimC
| posted on 8/12/05 at 03:31 PM |
GTS W7DE...
See the GTS section.
shortie
| posted on 8/12/05 at 03:32 PM |
Out of interest why do you want it wider??
They would have to make wider fibreglass as well, so I don't think they would be very happy to do a one-off.
Have you looked at the W7DE kit from GTS Tuning?
donut
| posted on 8/12/05 at 03:55 PM |
The indy is one of the wider cars due to narrow trans tunnel.
smart51
MNR's vortx is a bit wider in the body than a book chassis and uses the standard sierra rear end. It isn't as wide as a GTS w7de, a Luego
viento or a Caterham "pie eater" as one magazine called it. It might be of interest to you.
marc n
| posted on 8/12/05 at 04:16 PM |
yep can confirm ours is 445 mm wide in the seat area
best regards
marc
| posted on 8/12/05 at 10:38 PM |
JK, might be a daft question but have you tried the fit of an MK Indy? If not, get yourself upto MK on Saturday and try a few out If you have, just
ignore the last comment.
ditchlewis
| posted on 9/12/05 at 09:39 AM |
I find the Mk wide enough even for me. I'm 6'1'' and 17+ stone and it is a comfy fit for me. As hellfire says try one.
ditch
