Gazz
posted on 25/12/05 at 05:10 PM |
What does 'swg' mean ?
Any ideas ? It is something to do with the metal used on the chassis.
rsk289locost
posted on 25/12/05 at 05:17 PM |
standard wire gauge
Google it!
Gazz
posted on 25/12/05 at 05:25 PM |
Found it. Very technical stuff.
[Edited on 25/12/05 by Gazz]
suparuss
posted on 26/12/05 at 08:11 PM |
not all that technicall, put simply its just a unit of measurement displayed in fractions of an inch. easy! 10g is a 10th of an inch 16g is a 16th of
an inch. how is that technical?
Russ.
Alan B
posted on 27/12/05 at 12:51 AM |
Hmmm..not quite Russ...
Yes 16g is almost exactly 1/16
but 10g is nearer 1/8
and 20g is nearer 1/32
So, bottom line....... look it up on a chart
TheGecko
posted on 27/12/05 at 01:09 AM |
quote: Originally posted by suparuss
its just a unit of measurement displayed in fractions of an inch. easy! 10g is a 10th of an inch 16g is a 16th of an inch.
That's a handy conversion - shame it isn't true for anything other than 16g
Like many of the gauge systems, SWG numbers are not based on any obvious mathematical relationship to the actual size they measure. The
16g=1/16"=1.6mm relationship is an unfortunate coincedence (and 1/16" is only approximate - it's actually 0.064".
Here's some SWG sizes:
SWG inch mm
10 0.128 3.25
12 0.104 2.64
14 0.080 2.03
16 0.064 1.63
18 0.048 1.22
20 0.036 0.91
22 0.028 0.71
24 0.022 0.56
26 0.018 0.46
A bit of research turns up the suggestion that SWG numbers are related by the relative weight of wire of that diameter, with each higher (even) gauge
number being 20% lighter than the preceding one. A bit of maths with the values at hand seems to disagree however, so who knows.
Anyway, there's a big list comparing lots of gauge numbers available
here.
Hope this is helpful,
Dominic
