ned
posted on 25/1/06 at 12:12 PM |
how strong is gas pipe?
I was given a length of steel pipe, looks like its been drawn or is seamed its about 16-18mm diameter and 2mm wall thickness.
Its got a series of numbers stamped down the side of it (on a section i won't be using) and i'm told it's gas pipe.
I want to use it for my column downlink extension, anyone know if its man enough and up to the job?
ta,
Ned.
[Edited on 25/1/06 by ned]
beware, I've got yellow skin
NS Dev
posted on 25/1/06 at 12:41 PM |
gas pipe is normally seamed pipe which is then drawn.
Personally I wouldn't use seamed pipe for a column downlink, though many probably would.
What size seamless do you need roughly, I should be able to post you a piece.
choice of either 21.43mm x 4.06mm or 17.46mm x 3.18mm
ned
posted on 25/1/06 at 01:31 PM |
the closest to the size of the sierra original downlink that I've chopped in half so i can sleeve it and weld on a 45degree cut, think 17x3mm
sounds closest, need about 500mm length.
I'll u2u my address over, thanks Nat.
Ned.
NS Dev
posted on 25/1/06 at 03:25 PM |
No probs, I'll get it in the post at the weekend if that's ok.
ned
posted on 25/1/06 at 04:15 PM |
marvellous, thanking you...
Ned.
