omega 24 v6
posted on 19/2/06 at 10:10 PM |
tunnel height
What height has everyone made their tunnels?
The book sizes seem very high when stiched in place.
ned
posted on 19/2/06 at 10:38 PM |
depending on how far back you get the gearbox the height is needed, especially once you get the brake/fuel lines in etc
Ned.
beware, I've got yellow skin
ecosse
posted on 20/2/06 at 09:15 AM |
250mm from floorpan to top rail (roughly book size?)
I'm not sure I could get away with much lower at the front with the remote gearchange assembly, but there is certainly plenty clearance at the
rear, although I am using the sierra axle, so no up/down movement to worry about (hopefully )
Alex
omega 24 v6
posted on 20/2/06 at 12:28 PM |
Ok so another optical illusion that's actually right.
Marcus
posted on 20/2/06 at 01:32 PM |
I made mine an inch higher than the book. Means I can fit the gear lever remote under the tunnel top. Looks much neater.
Marcus
Marcus
Because kits are for girls!!
