New Topic New Reply
Author: Subject: chassis
bass
posted on 17/4/02 at 08:32 PM Reply With Quote
chassis
could any body tell the measurement from FU2 to FU1 ACROSS CHASSIS out side measurements. please
posted on 18/4/02 at 07:19 AM Reply With Quote
Not sure what you mean...
...but I would only tack FU1 and 2 in place anyway, until the time comes to set up the suspension brackets and weld them.
I fully welded these pieces in place when I started to make my chassis - and had to cut them away and re-make them when I got to fixing on the suspension.
Or had you some other reason for asking?
jmbillings
posted on 18/4/02 at 03:39 PM Reply With Quote
Not sure exactly, but after speaking to MK he pointed something out, that we would have missed otherwise- the tops of them shouldnt line up exactly to the edge of the chassis sides, but be inboard a few mm, otherwise the castor angle gets buggered by the rear of the top wishbone moving out, thus the endpoint moving forwards... Hope I explained that OK!
bass
posted on 18/4/02 at 05:55 PM Reply With Quote
yes i know what you mean about the wishbone, but if you look at page 41[first book] there is a drawing 0fviews through chassis frame FU1, FU2, E. what would be the measurement between top rails J1, J2 ?
New Topic New Reply
