caber
posted on 26/3/06 at 06:53 PM |
engine position
I set the engine and drive in position yesterday. The engine, a pinto, is currently sitting with the pulley over the furthest forward cross member and
there is about 35mm between the backof the bell housing and the bulkhead position. This is about 25mm further forward than I anticipated. I can either
live with this or extend the trailing links by 25 mm and move everything back. If I do this what effect will the extended wheel base on suspension and
steering geometry? I it worth it to move the engine back?
I am also in trouble with space on the driver's side engine bay. I have a conflict between the alternator and the steering, I already have a
Micra alternator but the standard bracket makes it foul.
I could also use some suggestions on the exhaust I can't see a viable route certainly the one I got isn't going to fit . Finally the brace
won't go this side I don't suppose there is a problem moving it to the other side?
TIA for any ideas
Caber :-)
DIY Si
posted on 26/3/06 at 06:59 PM |
Why would you need to extend the trailing links? Not sure how this is affected by engine position.
Can the alternator be moved to the other side? I've heard of people doing this before.
The exhaust could either go through the body work/pnels or as mine will and go over the chassis/through/under the bonnet side.
Could the brace be replaced with a y brace rather than the normal straight one? I've done this, and am putting one on both sides of the engine
bay.
caber
posted on 26/3/06 at 08:46 PM |
Engine + gearbox + propshaft + back axle = 1" too long! On the pinto the distributor is at the front on the opposite side so nowhere to put
alternator. On the right side I can probably make a custom bracket to lift the alternator however the top mount on the alternator then hits the short
brace at the front
Caber
DIY Si
posted on 26/3/06 at 09:14 PM |
Ah, didn't realsie you already had a prop. Is ther anywhere else level with the front pulley where the alternator could go? As long as the
belt's lined up, it doesn't matter where it goes.
Chippy
posted on 26/3/06 at 09:52 PM |
Building a Locost, (read highcost), is a bit of a jugling act. In my opinion its good to have the engine as far back as possable, if this means having
your propshaft altered, or even having a new one made, (about £120), then thats a small price to pay. I didn't fit my engine bay braces untill I
had the engine position settled, so maybe cutting these out and redoing is worth it at little or no cost. As to the alternator, I think that the only
route is to fabricate a bracket to fit on the opposite side, I had to do this. I know I have a different engine, (2.9i V6), but if you have a look at
my photo archive there is a picture of the bracket I made, which may give you some ideas. Keep up the good work, eventualy it all comes together. ATB
Ray.
NS Dev
posted on 27/3/06 at 02:37 PM |
prop shorten is normally about £50 cash if the UJ's are in good condition.
For the sake of £50 it's not worth compromising engine position.
Plenty of propshaft places near quarries and the like, that's where most of their business comes from.
caber
posted on 27/3/06 at 05:24 PM |
Will 25mm make that much difference to the balance? What about the option of lengthening the trailing arms? that is a more or less zero cost option at
the moment, my wheelbase would lengthen by 25mm so I suppose the balance point only moves 12.5mm back.
This is at the end of the day a road car not a racer so is the problem that serious?
Caber
Chippy
posted on 27/3/06 at 10:20 PM |
Not quite sure what you refer to when you say trailing arms, nothing comes to mind. The main advantages to getting the engine back as far as possable
is that the gear lever will end up nearer to you, (and not under the dashboard), and the weight will be better distributed. Keep fighting, you will
get there in the end. Regards Ray
caber
posted on 27/3/06 at 11:04 PM |
Trailing arms be the bits that hold a live axle on! They constrain vertical movement the Panhard rod constrains horizontal movement within an arc.
legthen the trailing arms then you lengthen the wheelbase
Caber
locost_bryan
posted on 28/3/06 at 03:12 AM |
I've read quite a few posts recommending longer trailing arms - isn't their length one of the discrepancies in the book?
What caber is saying, is that if he moves the engine back by one inch, then the gearbox, propsharft, and differential also move back by one inch.
An one inch increase in wheelbase won't make any noticable difference to the handling (unless you're M.Schumacher ).
Longer trailing arms sound like the locost-est solution
... and go for two y-braces in the engine bay - will improve the handling by stiffening up the front end
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
owelly
posted on 28/3/06 at 03:38 PM |
Am I the only one who can't see why you arn't shortening your own propshaft?? I have just chopped 8" out of a brand new one (I got
of JeolP. Cheers matey!!). it took a short time to make sure it was perfectly straight and the yolks were in line but it cost me nothing but a bit of
MIG wire.........and black paint. If it is out of balance when it's up and running, then I'll get it balanced.
http://www.ppcmag.co.uk
DIY Si
posted on 28/3/06 at 04:19 PM |
Longer trailing arms should help improve things a little as they allow slightly more twist at the back end. However, do you have space for this?
Remebering space at full bump and droop. If you do, then it's up to whatever you feel most comfortable doing. Unless you have to alter/make a
gear lever extention. But then that depends on how long/how much this costs etc.
caber
posted on 28/3/06 at 07:31 PM |
When I did the initial measure the back half of the capri prop that came with the back axle, also capri, looked about right so I got the spline stuck
on the end with a new Hardy Spicer joint. I am not sure where the measuring discrepancy came from but it is only evident now I have the bits
assembled, I suspect this is a result of using the tape measure as the primary measuring equipment!
I am beginning to think I should leave it for now and make sure there is space to move things back later. The next thing is the transmission tunnel. I
have heard two different theories on this. First is that it is a vital structural member therefore it should stay the same. The second is that it is
structurally irrelevant therefore can be messed around with. I did notice that the Lotus design is a triangulated structure that stops the car folding
in the middle. I would like to reduce the height of the tunnel to give a bit more cabin space.
Caber
DIY Si
posted on 28/3/06 at 08:25 PM |
The height of the tunnel can be lowered, but I would definitely weld in panels. The tunnel IS structural as it is the backbone for the chassis. You
can add triangulation if you wish, certainly won''t hurt anything. Adding a few kg's to the chassis in the form of triangulation is
worth it. The extra weight is more than offset by the gain in stiffness if done correctly. Better to have a stifffer but slightly heavier chassis and
lose a few kg's elsewhere. Read what I hope will be the attachment to this. Thanks go to cyntriks for the work. (if you want this removed please
tell me and i'll do so)
DIY Si
posted on 28/3/06 at 08:30 PM |
try again.
This is the smaller old version. The newer version I've got is too big. Any idea how to get it up anywhere?
[Edited on 28/3/06 by DIY Si]
posted on 28/3/06 at 08:35 PM |
I'm with Owelly on this. Put everything where you want it then make the prop fit the gap. You won't have enough of it left to need
balancing as long as the ends are in the right orientation so it doesn't phase.
posted on 28/3/06 at 08:56 PM |
i have another spare prop actually if anyone wants one
sorry caber, that doesnt help. Myself, id leave it where it is as a first choice, then lengthen the trailing arms as a second. Doing the prop would
definately be my last choice, id weld steering arms all day but not my own prop.
[Edited on 28/3/06 by JoelP]
NS Dev
posted on 28/3/06 at 11:23 PM |
still don't understand, compromise the whole car build to save £50 on a prop.............................total
no-brainer?????????????????????????????
caber
posted on 29/3/06 at 07:18 AM |
NS DEV the initial question was does mounting the engine 1" further forward than would be otherwise possible compromise the car?
Caber
James
posted on 29/3/06 at 08:04 AM |
Caber
At the end of the day, the further forward it is the more it knackers the weight distribution. How much that actually matters though is a different
matter.
I put mine back so the engine was against the bulkhead with the bellhousing fully inside the tunnel. So about 12-14 inches further back than yours.
Means a shorter (and lighter) prop and better weight distribution.
Further forward will also make it harder to fit the bonnet without a bulge.
Hope that helps,
James
- Muhammad Ali
caber
posted on 29/3/06 at 08:35 AM |
James
I don't see how I can get the bell housing in the tunnel.I am building a book width car and there would be no room for feet and pedals if I were
to reduce the width. What is the practical minimum distance between the back of the bell housing and bulkhead to preven the engine hitting it during
acceleration and braking on standard rubber mounts?
Caber
NS Dev
posted on 29/3/06 at 11:20 PM |
On rubber mounts (harder ones but they are only £7 from rally design) I have 5mm (at most) between the end of my clutch master cyl and my
bellhousing.
I wasn't "having a go" about the engine position, I have just learnt the hard way that if you don't try and get everything you
can think of "ideal" to start with, the list of things you are unhappy with is huge by the time you are on the road and you no longer like
the car!!
been there and done that!
procomp
posted on 30/3/06 at 07:45 AM |
hi yep ive senn westfield owners spend hundereds to move the engine back an inch .
please dont weld your own prop ive seen what can happen. as ns dev says for the sake of 50 quid.
cheers matt
posted on 30/3/06 at 09:46 AM |
I did mine and it's still going after 5 years. I've seen prop failures but it's always been on a UJ cracking up not the actual weld
or metal breaking.
NS Dev
posted on 30/3/06 at 10:20 AM |
yes, but you can see Matt's point Pete. Many on here could do it perfectly well, but one mistake would make for a particularly long disaster
topic on here.
I prefer to give the job to my prop place (premier props in hartshill) as I would need it balancing anyway.
