New Topic New Reply
Author: Subject: wishbone brackets
phil m
posted on 20/4/02 at 04:17 PM Reply With Quote
wishbone brackets
Please can anyone help. I'm trying to position the brackets for the top-front wishbones. The book isn't clear on the relative positions of the top to bottom one. ie does the centre of each need to be in line ? Also does the wider side of the top one face the front ?
thanks in aticipation , Phil
UncleFista
posted on 20/4/02 at 08:18 PM Reply With Quote
Hold it right there !
I've just asked the same question in the "Running gear" section
Good luck
Tony Bond / UncleFista
UncleFista
posted on 22/4/02 at 08:54 AM Reply With Quote
It looks to me (after consulting the book) that the top wishbone needs to be set back slightly. Cleverly the top wishbone is engineered to set it back a bit while actually sitting central to the bottom wishbone.
Hmmm, doesn't make much sense, it did in my head... basically set 'em up central, the offset is taken care of by the upper wishbone.
phil m
posted on 22/4/02 at 06:01 PM Reply With Quote
phil m
posted on 22/4/02 at 06:05 PM Reply With Quote
thanks --looks like it's more straight forward than thought --thats the problem with reading too much about these things -it tends to confuse ! : :
UncleFista
posted on 22/4/02 at 09:35 PM Reply With Quote
Theres a jig for easy(er) fitment here http://www.designdraughting.pwp.blueyonder.co.uk/photo.htm
HTH
New Topic New Reply
