New Topic New Reply
Author: Subject: R1 engine chassis
nitram38
posted on 30/4/06 at 08:49 AM Reply With Quote
R1 engine chassis
I am designing my new project chassis and I have my engine dimensions. It is going to be mounted at the rear end.
I want to make the area behind the engine as short as possible.
I know that a starter/reverse will be mounted above the output sprocket.
How much space (longitudinally), should I leave for mounting a chain driven diff?
[Edited on 30/4/2006 by nitram38]
MartinDB
posted on 30/4/06 at 04:16 PM Reply With Quote
I can measure the length of this
Image deleted by owner
tomorrow if you want.
Martin.
nitram38
posted on 30/4/06 at 07:50 PM Reply With Quote
If you wouldn't mind.
Where did you get it from?
Martin
kb58
posted on 30/4/06 at 08:15 PM Reply With Quote
Any chance you have the R1 engine modeled in Solidworks?
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
MartinDB
posted on 30/4/06 at 08:22 PM Reply With Quote
It's a standard R1ot diff carrier from Sylva, bolted to their R1 engine carrier. It uses a mk2 XR2 diff, CV joints and driveshafts and an R1 sprocket with their own cover.
I believe they're happy to sell them seperately.
Matt and Steve are both at Stoneleigh tomorrow on the Sylva register stand.
Martin.
nitram38
posted on 1/5/06 at 07:03 AM Reply With Quote
Thanks for the info on the diff. I will give them a call as I have to work today, so no stoneleigh.
I do not have the R1 modelled in solidworks, but I can tell you that the 2006 engine is approx 19" wide, 20" high and 20" from furthest forward point to the rear most point. (the engine is tilted more than the 2005 one but don't ask how much!)
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 1/5/06 at 08:41 AM Reply With Quote
the 2006 is externally identical to the 2004-2005 the only differences are internal.
(the intake ports and the engine map according to yamaha but ive got both a 2005 and 2006 head and they look identical though)
MartinDB
posted on 1/5/06 at 09:21 PM Reply With Quote
From the rear of the engine to the rear of the carrier is 37cm. The carrier is 16.5cm wide.
Martin.
nitram38
posted on 1/5/06 at 11:03 PM Reply With Quote
Cheers Martin
Martin!
New Topic New Reply
