big_wasa
| posted on 7/5/06 at 02:44 PM |
Does this need more bracing ?
Showing a mate a few photos of progress on the new chassis and he felt I need more bracing. I have beefed up O3 to 50x25x2mm and its a live axle car
so no diff hanging from it ect
What do you guys think ?
flak monkey
| posted on 7/5/06 at 02:57 PM |
Can do if you like.
Not really necessary as that part of the car isnt that structural... The axle loads go through the tubes where the trailing arms mount. In a live axle
car theres pretty much no load on the bulkhead.
Sera
http://www.motosera.com
ned
| posted on 7/5/06 at 03:17 PM |
In my pic below I think A will add more strength to the trailing arm bracket tubes, B will add more strength to the rear of the chassis, along with a
fully braced rollbar and I put the tubes in at C but I hadn't doubled up the tubes between the rollbar base plates like you have so probably
unecessary in your case but certainly a belts and braces approach. I was concerned about the single top rail twisting under the weight of two people
as that rail takes most of the forces in a heavy braking/accident scenario.
Ned.
beware, I've got yellow skin
gary gsx
i did but then my diffs hanging off it
| posted on 7/5/06 at 03:31 PM |
Yes -- "union jack" style
Kissy
| posted on 7/5/06 at 04:26 PM |
The 50x25 was overkill IMHO. The diagonals you propose are useful as they contribute significantly to the torsional stiffness of the chassis
DIY Si
| posted on 7/5/06 at 04:50 PM |
Could you put a steel bulkhead in? It's what I'll probably end up doing. But even then I have another box structure hanging on the back of
the tunnel to hold my diff up so no real need for extra bracing.
| posted on 7/5/06 at 05:05 PM |
i would add a 19mm round bar, in 20g. Next to no weight but pretty effective as it's in tension and compression if the bulkhead was to ever try
folding up. But if you intend to panel it, which i suppose you have to, then either welded steel or bonded and riveted ally will be more than
adequate.
zilspeed
| posted on 7/5/06 at 05:57 PM |
Nice neat looking work.
I know that adds nothing to the thread, but it needed saying
Bones V. Soon
| posted on 7/5/06 at 06:14 PM |
I put the extra diagonals into my chassis. My thoughts were that in the event of a roll the rear bulkhead would be carrying a lot of force and you
wouldn't want it to lozenge. I also have the vertical members going to the top tube as I am using Cobra hoops so the 'O' bar needs
extra support in the middle.
big_wasa
| posted on 7/5/06 at 06:48 PM |
Bones V. Soon
Thanks, ive updated my archive a bit with a few more pics.
Im going to bond and rivett an alloy floor hence the 30x3mm stringers to take the seats.
Thanks for the input chaps
Liam
| posted on 7/5/06 at 08:08 PM |
quote: Originally posted by flak monkey
In a live axle car theres pretty much no load on the bulkhead.
Erm..... apart from all the suspension loads which go straight up into the corners of that bulkhead!! Stiffness of the rear bulkhead is vital to the
torsional rigidity of the car, live or irs. Without it it's an open box - floppy. I'd put the tubes in.
Liam
flak monkey
| posted on 7/5/06 at 08:13 PM |
Yup, but those loads are vertical only. The two angled rear tubes, and the side tubes of the rear bulkhead will take these loads as they are purely in
tension.
Of course adding in 2 tubes will increase the stiffness of the chassis, as nothing beats a properly triangulated stucture. But the tubes are not 100%
necessary, especially with that huge tube running across the back anyway. My original answer was on a neccessity basis rather than anythign else.
Makes little difference. Depends if you are bothered about another kilo on the weight...
Sera
Liam
| posted on 7/5/06 at 08:25 PM |
Load might be vertical, but when it's only on one side, i.e. any one wheel bump or corner, it will act to lozenge the rear bulkhead, and the
whole chassis. A chassis without a torsionally stiff rear bulkead will flex horribly under hard cornering.
Of course you could take the american approach - "if we put enough big horizontal bars in we dont need triangulation!" . I never
said that chassis needs those bars but any triangulation is an elegant way of increasing the efficiency of the structure. Loosing that unnecessary
2"x1" bar and adding the diagonals instead would have resulted in a chassis the same weight and much more stiff.
Liam
[Edited on 7/5/06 by Liam]
