Jumpy Guy
posted on 25/5/06 at 04:06 PM |
the opposite of threaded rod- numpty question
Can you buy lengths of round steel which is threaded down the middle?
ie the opposite to threaded rod.
i know that i could use steel and drill and tap it, but dont have a pillar drill etc...
MkIndy7
posted on 25/5/06 at 04:33 PM |
Can't say that i've ever seen any.
In the Heating and Ventialtion industry they do have Sockets for joining screwed rod together when holding up pipes and ductwork etc if your just
trying to extend a piece?
Jumpy Guy
posted on 25/5/06 at 04:37 PM |
Have to extend my wing stays sideways, on wee pillars.
I was going to weld pillars to the stay plate, then bolt through the upright into the pillar....
Mad Dave
posted on 25/5/06 at 05:05 PM |
Like this?
Image deleted by owner
(yes, I know its not round!)
[Edited on 25/5/06 by Mad Dave]
viatron
posted on 25/5/06 at 05:13 PM |
Local machine shop should knock you up what you want for peanuts. Or as you already said just weld a piece of tube in as a spacer.
Mac
Jumpy Guy
posted on 25/5/06 at 05:41 PM |
Dave, thats the very thing...
where to buy?
fesycresy
posted on 25/5/06 at 06:29 PM |
You can buy a "long nut", 1" or so long, tapped M8 or M10, from any electrical wholesalers like CEF.
And yes they are called long nuts.
Dusty
posted on 25/5/06 at 06:53 PM |
Saw the same in Wickes DIY in the roofing accesories section. M8 M12 possible M10 along with lengths of threaded rod. Probably not high tensile.
[Edited on 25/5/06 by Dusty]
joneh
posted on 25/5/06 at 07:36 PM |
You can also get similar things called "standoffs" used in the PC market. Somewhere like Maplin/RS/CPC should do them. They only have an
m3 thread though - not sure if thats to small for you?
posted on 26/5/06 at 08:13 AM |
how long and what thread?
you can buy (well, my local fastener shop sells them) stud connectors; bascially a hex tube that is threaded inside for joining up studs, as per your
description.
