t.j.
posted on 27/5/06 at 07:19 PM |
lower wishbone Avon
So, i've some screenshots.
This how i wanted to make my front.
The "orange-book" says 10 mm plate between the two pipes. Yesterday we discussed the thicknes. The pipes will be 25x3 St37-2 also the 10 mm
plate. Low. Ball-joint Fiat 124.
Ps. the upper brackets are placed about 20 mm more inwards to fit other bonnet and nose-cone.
roll-centre= + 45 mm
bump-steer= zero (calc)
cambergain= +0.3 degr by 1 inch
inst. centre about 3 metres :-) outside car.
Let discuss!
DIY Si
posted on 27/5/06 at 07:26 PM |
I still think 10mm is too thick. Any idea what St37-2 is in english terms?
t.j.
posted on 27/5/06 at 07:38 PM |
I know
could you give your opinion on my engine mounting? http://www.locostbuilders.co.uk/viewthread.php?tid=44419&page=1 (last page, pictures!)
Fe360=St37-2=S235JR
grtz
[Edited on 27/5/06 by t.j.]
DIY Si
posted on 28/5/06 at 12:20 AM |
As per the engine mounts,if you can get them on to the lower chassis rails, it would be better, but if leaving them there is easier, them make a
complete box if poss to put the mount on top of. Hope this comes out ok:
Also do the same front and back if poss.
[Edited on 28/5/06 by DIY Si]
