<<  1    2  >>
New Topic New Reply
Author: Subject: Engine height
ADD
posted on 18/7/06 at 11:29 AM Reply With Quote
Engine height
gearbox line up
gearbox line up
Hi All,
As you can see due to my change of plan I now have an engine height issue.
Has anyone else tried fitting a tall engine. If so how have you got round the problem?
Or do you think that it will be OK and will just have to sit on a cusion!.
Adam
Ketchup
posted on 18/7/06 at 11:36 AM Reply With Quote
whoa.. u may need a periscope!
rayward
gonna need a BIGGGGG hole in your bonnet
Ray
Confused but excited.
posted on 18/7/06 at 11:40 AM Reply With Quote
Now that's what I call a lump !
You could always lower it and fit24" rims for sump clearance.
kb58
posted on 18/7/06 at 01:50 PM Reply With Quote
<Crosses arms, rolls eyes, shakes head, taps foot of garage floor...>
Geez, does anyone ever thing to measure stuff first? It's not like a Locost is a fully-baked, completely-researched, guaranteed-to-fit, screw-it-together-in-the-dark kind of kit.
You as designer... yes, designer, have to measure stuff. Yes, some brain work needs to go into these things; nothing is completely engineered for you ahead of time.
So much for stating the obvious, in hindsight. All lecturing aside, thanks for posting the picture, it's a valuable lession learned, for everyone.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
posted on 18/7/06 at 02:10 PM Reply With Quote
OK - we're all taking the mickey, or giving lectures, but it doesn't help Adam much - it would be more useful to him if we could offer solutions (even if it ends up as "use a different engine" ).
Adam - a good side-on picture would be useful so that we can see if it's as low down as possible.
Can any of those bits on top be removed and placed elsewhere?
What is that engine anyway? Folks have certainly fitted V8s before (e.g. the Rover/Buick lump) but that one looks very tall. Even the Dax needs a hole in the bonnet/hood.
cheers,
(who isn't really trying to upset anyone... not today, anyway! )
[Edited on 18/7/06 by David Jenkins]
clbarclay
posted on 18/7/06 at 02:47 PM Reply With Quote
The engine looks like a v6 given the angle between the 2 banks of cylinders, though exact engine details would be nice
V8s have the cylinder banks angled further apart, which generally makes them slightly wider, but not so tall.
Various otions for you to consider.
1 find a different engine to use
2 Build a new chassis thats taller to acomidate the engine.
3 Some manuthactures make slightly taller fibre glass than others, but only by an inch or 2 so probably won't be enough
4 Start designing a big bonnet bulge or vent. In the second edition book there is a picture of a locost using a rover v8 that has a big bonnet bulge/vent to accomidate the engine.
5 Correct me if i'm wrong, but i think you can have the engine sticking out of the bonnet for SVA, but it must comply with all the sharp edges etc. like the rest of the body work and exhaust.
[Edited on 18/7/06 by clbarclay]
ADD
posted on 18/7/06 at 03:15 PM Reply With Quote
I know, I know. I did measure it all first, realised it was going to be big and said sod lets just deal with the cociquences when I get that far.
The engine is 1 24V 2.9 Cosworth lump from a granada scorpio.
Its got an ally sump with groves up the sides to accomodate the bolts so very difficult to shorten the sump.
In the picture the chassis is raised and inch and the sump is on the deck.
I am thinking of putting an extra rail around the top of the engine bay, making the nose cone taller (cut and shut) and placing bonnet on top of the raised section.
what do you rekon?
graememk
posted on 18/7/06 at 03:33 PM Reply With Quote
6" of foam rubber to sit on or look for another engine as that just isnt going to fit.
posted on 18/7/06 at 03:42 PM Reply With Quote
Doug (a.k.a. garage19) has a decent 2.0 litre zetec for sale... (or did, a week or so ago) and that's just south of Ipswich.
leto
posted on 18/7/06 at 03:47 PM Reply With Quote
It will still be tall, you will lose the proportions of the car and it might look strange.
Cut the sump or make a new one. A high scoop is properly better than a high bonnet.
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
Marcus
posted on 18/7/06 at 04:01 PM Reply With Quote
The sump should still be reasonably easily modified - just weld it on the inside.
That should give you an inch or 2. Build the sides of the chassis up another inch, and drop the engine a further 1/2 inch - you may be somewhere close.
Go for it
Marcus
Because kits are for girls!!
Alan_Thomas
posted on 18/7/06 at 04:05 PM Reply With Quote
Seriously, If you are planning to SVA you will never get the sight lines required, you are either going to have to use a 'dining room chair' as a seat or think again about the choice of engine. You will never get enough height reduction however you chop the sump (dry sumping would make the most difference but still nowhere enough).
Lovely engine - perhaps you should change the type of car you are building!
- Alan
kb58
posted on 18/7/06 at 04:19 PM Reply With Quote
Okay, I'll be more helpful...
I don't think the sump should be cut down... it's the last thing to do with an engine that's going to see high G-forces. A dry-sump is the best (though expensive) solution, and might be needed anyway. You can raise the sides of the car as mentioned, add a big scoop... geez, it's a small car man!
Worst case, without giving up on your dream entirely, would be to trade that engine for another V6 that's a lot shorter.
zetec7
posted on 18/7/06 at 06:55 PM Reply With Quote
I'd suggest another engine choice. Aside from the sight-line issue, body design issue, weight distribution issue, etc., the centre of gravity is going to be very high. The car might be very tippy indeed. The Zetec is only 24" high...
DIY Si
posted on 18/7/06 at 06:58 PM Reply With Quote
As Hellfire seems to be a little slow off the blocks today, may I suggest a nice bike engine? Nice and low, and light, and more than fast enough. See the York drag day results.
ADD
posted on 18/7/06 at 07:28 PM Reply With Quote
OK now you have me worried, whats all this about sight lines?? Its the first time I have heard this one.
locostv8
posted on 18/7/06 at 11:49 PM Reply With Quote
Here is a thread on shortning t aloy sump whilde not reducing the volume. http://www.locostbuilders.co.uk/viewthread.php?tid=46627&page=2
Something else I would think could be done is move the coil pack and whittle down or fab a new intake. This wouldn't work for your engine but these are what I'm doing for a 351 Ford, possibly something similar could be done to at least limit the lump to the center of the hood, oops bonnet. Pointing the throttle body toward the firewall.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
clbarclay
posted on 19/7/06 at 09:40 AM Reply With Quote
In any 7 style car you sit a lot lower than most road cars. Imagine sitting in your car when its finished and not being able to see the road in front over the bonnet because the engine too tall.
If you can try sitting in another 7 style car with a friend to hold a piece of wood etc. at the same height as your engine will come (with and without shortening) and see how much it would affect the visibility.
[Edited on 19/7/06 by clbarclay]
Alan_Thomas
posted on 19/7/06 at 04:15 PM Reply With Quote
When I took my SVA test the tester sat in the car and tested (in his words) that he had "unimpeded forward vision"
- alan
wilkingj
posted on 19/7/06 at 06:51 PM Reply With Quote
Get a Viento Chassis... It would look lost in the engine bay
Best Regards
Geoff
http://www.v8viento.co.uk
MustangSix
posted on 19/7/06 at 08:13 PM Reply With Quote
I think you have the eingine mocked up too high. It appears that the crank centerline is very high and the transmission output is very close to the top of the tunnel.
I may be wrong, because the photo is at an angle and difficult to accurately judge, but I think you should try a mock up with the chassis at least another inch or two higher relative to the drivetrain.
You will certainly lose some ground clearance, but you should still have enough.
Simon
posted on 19/7/06 at 11:03 PM Reply With Quote
Section 8 - Glazing, of the SVA manual states:
1. Check that, when seated in the driving position, the driver has a full unobstructed view of the road to the front and forward of the nearside and offside of the vehicle. The lower edge of the forward field of view must not be above the "windscreen horizontal plane" as defined in the annex to Section 2 (Defrosting/Demisting) of this manual.
Annex to Section 2 (Defrosting/Demisting) says:
Take note of it!!!!!!!!!!! I had to cut 2" from the top of my bonnet between test and retest!!
Should be clear as mud now!!
I would suggest you drop your engine by another couple of inches at least. I have about 1.5" ground clearance and a sump guard about 1/4" lower. Latter takes a bit of bashing
HTH
Simon
posted on 20/7/06 at 10:24 AM Reply With Quote
Good grief!
You'll need to stand up to drive that fecker . Get a Cobra to fit it in or build a hot rod, you are missing the point of the car.
ADD
posted on 20/7/06 at 11:43 AM Reply With Quote
Exactly what is the point of MY car then!! In my eyes the point of my car is to enjoy building it, learn some new skills. If you are talking about the lowcost, low-weight aspect of it then I am afriad that is all lost on me!. However, the car as it stands at the mo only cost me about £500 this includes all the running gear, all I need is some ali sheet and seats. And I only weigh in at 57KGs so I have a big weight advantage before I even started.
Anyway, I think the decision is to raise the chasiss in relation to the engine and aim for 3 inch sump to ground clearance.
<<  1    2  >>
New Topic New Reply
