Author: Subject: Ignition Coil
miserableoldgit
posted on 18/7/06 at 09:15 PM Reply With Quote
Ignition Coil
What sort of resistance should there be between the Primary and Secondary Coils, mine reads 1.9 Ohms; doesn't seem a lot. :
Youth and vitality are wasted on the young
caber
posted on 18/7/06 at 09:47 PM Reply With Quote
Resistance between + and- on coil should be about 3.4 ohms for a 12V coil and 1.9 for a coil to be used with a resistance wire or ballast resistor. IIRC most rover v-8 have a resistance wire for running and a link from a spare teminal on the starter solenoid to provide 12V while cranking.
Caber
miserableoldgit
posted on 18/7/06 at 09:49 PM Reply With Quote
Ignition Coil
Thanks Caber
Coil has label stating Ballast Resistor required, but mine doesn't seem to have one. 1.9 Ohm just didn't seem at lot.
This isn't for the V8 by the way, this is on the old Ford Xflow.
[Edited on 18/7/06 by miserableoldgit]
posted on 19/7/06 at 10:35 AM Reply With Quote
1.5 ohm for ballast
3 ohm for non ballast i.e. direct to 12 V.
Marcus
posted on 19/7/06 at 11:30 AM Reply With Quote
On the old crossflow, the ballast resistor is built into the loom. Its a light grey or white resistance wire joined to the coil +ve lead.
Marcus
Because kits are for girls!!
