doughie
posted on 6/8/06 at 06:40 PM |
Roll Bar Diameter - SVA
Hi
have tried serachin to no avail
can any one let me know the minimum diameter of a roll bar to satisty mr SVA?
DIY Si
posted on 6/8/06 at 06:42 PM |
I've heard various versions, either 1.5"/37mm or 1.3/4"/44mm
big_wasa
posted on 6/8/06 at 06:43 PM |
No roll bar needed for sva
suparuss
posted on 6/8/06 at 07:01 PM |
the only reference to roll bar thickness/diameter in the sva manual is relating to recomended seat belt achorages. if you dont have one you just need
to mount the seat belt somewhere else.
Russ.
doughie
posted on 6/8/06 at 07:50 PM |
will be looking to fix four points to chassis...
with the roll bar - thinking there is a minimum diameter - - mine is 45mm????
ta for all your replies
posted on 6/8/06 at 07:58 PM |
Roll bar is not needed for SVA so no minimum diameter or thickness or material specification or colour or anything. If you fit one it will
be tested for edge radius compliance.
DIY Si
posted on 6/8/06 at 08:02 PM |
I thought it depended upon how it was fixed, ie if welded it becomes structural and as such has to suitable for the application. But if bolted its
cosmetic.
posted on 6/8/06 at 08:52 PM |
nope the same reason they dont need to measure the output on the flux capacitor, because you dont need one.
As pete says, the terminals on the flux thingy still need to be radiused.
Chippy
posted on 6/8/06 at 10:12 PM |
As stated "no requirement", but if you bolt one on the SVA inspector will check that the bolts are at least 8mm dia, and that they are
marked 8.8 or better. Regards Ray
James
posted on 7/8/06 at 08:22 AM |
Atleast 11mm diameter!!!! Or 7/16ths.
James
- Muhammad Ali
NS Dev
posted on 7/8/06 at 09:57 AM |
yea, normal "safety" anchorage bolts are always based on 7/16" UNF (no idea why!)
t.j.
posted on 7/8/06 at 05:58 PM |
And that's even standard in the rest of the world!
It's coming from UN-standard regulation
Now you know
Chippy
posted on 7/8/06 at 10:22 PM |
James, I hate to say this, seeing as how I have now met you and feel you are a nice guy, . But you are wrong!!! it's the seat belt
anchorages that need to be 11mm/7/16" or better, the roll bar fixings need to be "at least 8mm x 8.8's" or better. Read the
SVA manual. Regards Ray.
James
posted on 9/8/06 at 08:21 AM |
No, I was right, it's just that we were talking about different things!
As you say, I misunderstood, and was talking about the seat belt bolts, not the rollbar to chassis bolts!
Sorry for the confusion!
James
- Muhammad Ali
doughie
posted on 9/8/06 at 08:40 AM |
ta for all of the advice - so i'll be ok with the 45mm diam roll bar (it's welded on)
