New Topic New Reply
Author: Subject: plans
ex-ctr
posted on 3/9/06 at 11:55 AM Reply With Quote
plans
hi every one im from the sxoc and have decided to scratch build my own lotus 7 copy
im using as s13 as a doner as i intend to use the whole rear subframe which holds all the link arms and diff, i will fit an s14 lsd
as well
going to run the ca18det with a fast spooling turbo rated at 250 bhp to get around lag.
now to come to the point which plans would be best suited to my needs, i do understand that i will need to alter the design a bit but that would not be a problem as im a fab and welding engineer
thanks for any help that might come my way
also i've done a lot of searches
wilkingj
posted on 3/9/06 at 12:04 PM Reply With Quote
Welcome to the Mad house. There is lots of advice and help on here.
Please use the Search facility, as most things have been done to death and are somewhere in the archives.
www.mcsorley.net is a very good starting point. for well sorted plans.
There are several versions ie +4" +4+4+2"
ie wider, wider and taller, and wider and taller and longer.
I believe GTS tuning do nose cones for the wider versions, which may be of help.
Best Regards
Geoff
http://www.v8viento.co.uk
New Topic New Reply
