Schrodinger
| posted on 12/9/06 at 10:05 AM |
Laser cutting
Has anybody had parts laser cut?
If so where and what sort of price and what do the suppliers need?.
I am thinking of building a Rorty IRS chassis and was thinking of getting the upright parts laser cut.
NS Dev
| posted on 12/9/06 at 10:22 AM |
good suppliers will accept a .dxf file by email and quote on it and then do the cuts from it too.
Prices vary wildly but watch minimum orders, usually £40 or £50, either per drawing or per plate thickness.
Guinness
| posted on 12/9/06 at 10:24 AM |
I used to get parts laser cut for work. Most of the cost tends to be on the set up, so if you are getting 1 done the costs are higher than if you are
getting 10 plus! Start a bulk buy!
Helps if you can provide them with AutoCAD drawings too!
Let me know if you need them converting to CAD.
Mike
iank
| posted on 12/9/06 at 10:26 AM |
Interesting. Do you happen to know what they base their charges on? per inch (mm)?
I've got a dxf of something large (aluminium seat) that I'd like lasered or water cut, but I wouldn't want to waste their time if
it's going to be silly money.
Two seats and mounts fit on a 2.5 x 1.25 x 2mm sheet.
Tangerine Scream
| posted on 12/9/06 at 11:07 AM |
Could be worth contacting Jonathan Rarity. His business has a large CNC machine that is more than capable of cutting ally sheet. Amongst other stuff,
I know he has done sump baffle plates and air filter backplates.
His email is
jonathan "at" rarity.freeserve.co.uk
NS Dev
| posted on 12/9/06 at 11:11 AM |
depends on the place involved.
My local place (NSI in nuneaton, who are the biggest subcon laser cutters in the UK) would do that for you.
They work on a "is it worth the trouble" basis as far as I can see. If you need a whole sheet for the job then it probably is worth the
trouble of putting it on.
If you wanted 1 small bracket from the corner then probably not.
strictly "by the mm" prob doesn't work cos you could request some laser cut mesh that would not be worth doing even though it was a
lot of mm.
NS Dev
| posted on 12/9/06 at 11:12 AM |
Mike
the CAD file you want is no necessarily autocad, just needs to be in dxf format which most cad packages (if not all) can export files in.
Schrodinger
| posted on 12/9/06 at 11:28 AM |
I will look into getting a bulk buy going but first I have emailed Rorty to check that it's ok to use his drawings.
3GEComponents
| posted on 12/9/06 at 12:12 PM |
Is it parts like this you're after?
3GEComponents
| posted on 12/9/06 at 12:17 PM |
Is it something like this you're after?
I get them cut on a regular basis if you're interested.
Schrodinger
| posted on 12/9/06 at 12:55 PM |
That looks like part of it but I was hoping to get all of the parts cut for the uprights as they should be made from 3mm steel IIRC and that is a
barsteward to cut any amount of.
3GEComponents
| posted on 12/9/06 at 01:42 PM |
Do you have the dxf's?
Schrodinger
| posted on 12/9/06 at 02:58 PM |
No I don't all I have at the moment all I have is a PDF IIRC with the drawings in them.
Minicooper
| posted on 12/9/06 at 03:04 PM |
Is that plate for a sierra bearing carrier setup, what thiclness is that and also what approx price for a pair
zilspeed
| posted on 12/9/06 at 03:16 PM |
His email is
The current Scottish hillclimb champion Jonathan Rarity ?
(And a member of our club as well incidentally)
MikeR
| posted on 12/9/06 at 03:44 PM |
And se7ens list contributor - thats the one.
Schrodinger
| posted on 12/9/06 at 05:49 PM |
http://gtslocost.locostsites.co.uk/documents/pdf_files/RortyLocostIRSAssembly.pdf
the plans I have are from the above pages 23-1 to 23-11 if anybody could convert the pages into a CAD file I would be most greatful
iank
| posted on 13/9/06 at 09:51 AM |
Thanks to Mike (Guinness) for tipping me off to a local place he used to use (http://www.acornlaser.com/)
I requested an estimate based on the dxf at 1am, by 10am I'd got a quote. It's a lot less than I feared even for prototype quantities.
seat back, base and 2 sides cut from 1000x1250 is around £45+VAT+material if they source it, price reduces steeply with volume as expected.
Guinness
| posted on 13/9/06 at 11:00 AM |
Ian
Their rep has one of the most impressive business cards I have ever seen, it's normal credit card sized, stainless steel, about 1.2mm thick and
all his details, logo, email, phone, fax, address etc are cut through instead of being printed on. Like a very cool mini stencil.
Mike
NS Dev
| posted on 14/9/06 at 07:10 AM |
sounds very good!
By way of comparison, last job I had done was for some CD Deckstands, which were laser cut 380mm x 350mm rectangles, with 2 lugs press bent at 90
degrees, made from 4mm cold rolled mild steel plate, and the quote was £6.00 each incl material but excl VAT, based on 20 off (total bill was £120 +
VAT)
Aboardman
| posted on 17/9/06 at 01:08 PM |
I have emailed a local company who may offer this service and sent them some typical drawings for the IRS set up.
Aboardman
| posted on 17/9/06 at 01:11 PM |
i will put them on to cad for you
Schrodinger
| posted on 18/9/06 at 04:16 PM |
Thanks for the effort
