Gremlin
| posted on 15/5/03 at 10:17 PM |
Wishbone brackets
The wishbone brackets in the book has an external width of 48mm which would tell me that the internal width would be 42mm as the plate thickness is
3mm.
What length are the sides and is 42mm as an internal size right?
PS - Sorry about the really bad drawing but i did it quickly to try and help explain what im babling on about.
[Edited on 15/5/03 by Gremlin]
EZy GreMLiN
"The only way to get rid of temptation is too give in to it..!"
| posted on 16/5/03 at 09:05 AM |
If you are using poly bushes and bigger tubing you may need to alter the size from the book as the bolts are bigger. Best idea is to make them to suit
what you are using.
yours, Pete.
Gremlin
| posted on 16/5/03 at 10:11 AM |
Is the internal dimension correct or about right at 42mm?
EZy GreMLiN
Hornet
| posted on 17/5/03 at 07:59 AM |
Yes the dimension is 42mm, but the previous thread is correct.
I have bought brackets from doz racing and they are 41mm and I have since seen cad drawings on his site showing 42mm.
You really need to make your mind up now on what bushes you are going to use b4 you go ahead with making the brackets... Cheers
