New Topic New Reply
Author: Subject: chassis grinding problems
doughie
posted on 26/9/06 at 12:57 PM Reply With Quote
previous owner over zelous with his anglegronder and has ground the chassis tubes down in several places when dressing welds - should i weld angle iron to these areas to stiffen or is there a better way???
[Edited on 26/9/06 by doughie]
RazMan
posted on 26/9/06 at 01:05 PM Reply With Quote
Difficult to say without actually seeing an example. Can you post a pic or two?
Raz
John Bonnett
posted on 26/9/06 at 04:27 PM Reply With Quote
You should be able to build up the ground away parts of the tube if you have a MIG welder or if not, you could find someone who has. Using a flapper disc on an angle grinder you should be able to reproduce the original profile of the tube and nobody will be any the wiser. Strengthwise it will okay too.
John
Mark Allanson
posted on 26/9/06 at 08:00 PM Reply With Quote
I would put a 1" micrometer on the erw to see exactly how thin the steel has become. I certainly would not build up the thickness with a mig, you will get distortion of truley biblical proportions (would give you loads of neg caster though!).
If you do get a particularly thin bit, I would brace the joints with a few triangles of the same material to reinforce.
lexi
posted on 26/9/06 at 09:27 PM Reply With Quote
Two flat pieces at 90deg just cut a bit narrower than the tube. This will allow you to weld at the external corners of tube where it is thicker. Then 45deg brace welded to that will make it look like a designed strengthener.
All depends where they are and whether they will interfere with any detail.
You could just weld over it if you done it in short pulses allowing to cool in between if there were no room for above method but not as good.
If using first method I would us plate 0,5mm thicker.
Also if previous builder has went mad with grinder, check that he has not taken too much off other welds on chassis thereby weakening them.
Alex
New Topic New Reply
