New Topic New Reply
Author: Subject: Book Tunnel
goodguydrew
posted on 9/10/06 at 07:20 AM Reply With Quote
Book Tunnel
Hi, in the Book the plans show an angled widening at the rear of the transmission tunnel to clear the diff, but many of the pictures don't feature this. Before I weld up my tunnel for my escort axle, do I need this feature? Any advice would be welcome, thanks.
DavidM
posted on 9/10/06 at 07:44 AM Reply With Quote
Yes, it gives clearance for the diff which is offset from centre on the Escort axle. It also gives a bit more space for pipework to go past the diff.
The book shows the angle on one side only, but I did mine the same both sides because I like symmetry.
Proportion is Everything
Marcus
posted on 9/10/06 at 08:19 AM Reply With Quote
I would (did) make the tunnel 1" taller if I were you, gives better clearance for a gear lever remote.
Marcus
Because kits are for girls!!
Mark Allanson
posted on 9/10/06 at 06:18 PM Reply With Quote
Slightly off the topic, but make sure your uprights for the tunnel don't coincide with the wider rear section of the gearbox, caused me all kinds of problems
Marcus
posted on 9/10/06 at 06:31 PM Reply With Quote
Or a propshaft UJ
Marcus
locostv8
posted on 9/10/06 at 06:53 PM Reply With Quote
I think some of the best advice I have seen is to fab or atleast not fully weld the tunnel until the running gear is installed then make it fit.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
posted on 9/10/06 at 08:37 PM Reply With Quote
Which axle have you got, the Capri type is offset to the driver side. Check which one you have and centre it before you proceed.
New Topic New Reply
