smdl
posted on 10/10/06 at 06:15 PM |
Welding Suspension Brackets
Hi, All.
Should the suspension brackets be attached before or after the chassis is fully welded? My chassis fabrication is almost complete, but everything is
still just tacked. I am wondering if I should tack the brackets on now, and then fully weld, or wait until full welding is done so that I have an
opportunity to adjust the mounting points to accommodate any distortion.
Thanks,
Shaun
kb58
posted on 10/10/06 at 06:16 PM |
Wait until after. It allows hiding a multitude of fabrication sins and heat (welding) distortion.
Good for you to ask!
[Edited on 10/11/06 by kb58]
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
zetec7
posted on 10/10/06 at 07:53 PM |
I'm with kb58 on this one! Wait 'til after the frame's welded.
smart51
posted on 10/10/06 at 09:31 PM |
If the chassis moves or twists slightly when it is welded, it will move the suspension mounts with it. If you weld the mounts on afterwards, they
will be straight.
smdl
posted on 11/10/06 at 01:26 AM |
Thanks for the feedback. Yeah, at least I managed to ask ONE question in advance!! Usually, I do the damage first, and then ask for guidance!
Shaun
[Edited on 11/10/06 by smdl]
locostv8
posted on 11/10/06 at 05:33 AM |
Shaun
But that is how we learn lifes little lessons.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
