SALAD
posted on 23/10/06 at 07:35 PM |
POR15....again!
Long story short.....
Painted on the first coat, left for ages so sanded down in order to provide a suitable key then applied a second coat yesterday.
If I had done my homework properly I would have known to apply the top coat of ChassisCoat Black, 'when first coat is dry but with slight
finger-drag remaining, usually 4-5 hours'.
So now apparently I need to, 'use POR-15 Tie-Coat Primer directly on the cured POR-15 surface, then topcoat as desired' or use their
self-etch primer stuff that is good to top-coat in 30mins.
According to their laboratory test results, 'Recoatability is excellent. Laboratory tests have shown very good adhesion when applied up to 14
days after application of the first coat. In an actual Field test, a topcoat was applied 6 weeks after the first coat had been applied, and the
intercoat adhesion was excellent as determined by a crosshatch tape test'.............
SO, has anyone been in the same situation and what do we think is the best idea?
Either prime with the self-etch primer then top-coat or just give it a rub over with thinners of the correct type and slap the top-coat on.
I'm a tad mift as I had everything set up yesterday and even had a friend there to help. Now it's looking like I must purchase more
products and will undoubtedly be painting on me lonesome again
NS Dev
posted on 24/10/06 at 07:05 AM |
sounds like an extremely convoluted way of doing a chassis, would be cheaper to get powder coated after all that lot!!!!!!
