New Topic New Reply
Author: Subject: Chassis Infill Panel Thickness
smdl
posted on 6/11/06 at 04:08 AM Reply With Quote
I have read a few threads debating the merits of using aluminum or steel for the infill panels between the K's and the M's where the rear trailing arms mount. To be safe, I have decided to use steel, but am wondering what thickness I should use. I have some 14 gauge steel that I could use for this. Would this be appropriate?
Thanks,
Shaun
DIY Si
posted on 6/11/06 at 08:16 AM Reply With Quote
It's partly up to you. When I was making a chassis I used a massive panel of 3mm plate! This is quite probably overkill though, but all I had at the time, so I bunged it in. 14 gauge should be fine, and the other option or a bit of extra strength here is to make the two trailing arm brackets out of a single bit of 2 or 3mm box, cut the welded/seamed side off and have a the bracket extend up to the top rail, and down to the bottom rail.
Sun Tzu, The Art of War
mistergrumpy
posted on 6/11/06 at 10:31 AM Reply With Quote
Hey up. I used 3mm steel too after speaking with other members. Just don't wanna risk it bending and coming apart.
omega 24 v6
posted on 6/11/06 at 01:32 PM Reply With Quote
3mm steel in mines as well.
posted on 6/11/06 at 04:06 PM Reply With Quote
I've used 16 gauge on mine, and I thought that was probably overkill. Then again I made some very hefty trailing arm mounting brackets as well.
caber
posted on 6/11/06 at 06:40 PM Reply With Quote
I used 16 Guage and made trailing arm mounts from one bit of 50 X50 X3 RHS slotted for the armsand welded to the frame and sheet.
Caber
posted on 6/11/06 at 06:44 PM Reply With Quote
16 gauge for me too - plenty strong enough. The trailing arm brackets do most (if not all) of the work).
Using 50mm channel is a really good idea - I found out too late to do it on my chassis.
[Edited on 6/11/06 by David Jenkins]
smdl
posted on 7/11/06 at 03:40 AM Reply With Quote
Thanks for all the great replies. I am using rose joints for my suspension, so I have gone with brackets that are much narrower (1.25" OD) than the book standard units. This goes a long way towards minimising the overhang issues that come with welding 2" brackets on 1" RHS, and also shortens the span of the fixing bolt.
Shaun
New Topic New Reply
