New Topic New Reply
Author: Subject: chassis advice
quick n stuff
posted on 15/11/06 at 03:13 PM Reply With Quote
chassis advice
Hi im going to start building my locost affter the new year and i am affter a bit of advice. I will be making my chassis with the rorty IRS plans. could eneyone tell me if the have had eney problems with this and what dose it drive like as this will be a track day car.
Also i will be puting a toyota 4age engine in is there eney problems with puting this engine in. I will be using a type 9 gearbox with adaptor plate
and for my last bit of addvice can a big lad fit in a standard chassis not the +4 im 6'2" and about that wide.
Gav
posted on 15/11/06 at 03:19 PM Reply With Quote
Im 6ftish and have a larger than average PRR(Pie Retention Ratio ) and i can comfortably fit in a standard chassis, although i must admit id like an extra inch or two in the pedal area for my legs (33in inside leg).
Although it would be fairly easy to add the extra room in the drivers footwell while your building it without altering the chassis dimensions.
quick n stuff
posted on 15/11/06 at 03:30 PM Reply With Quote
thanks
big_wasa
posted on 15/11/06 at 04:47 PM Reply With Quote
I am 6'3"
You will fit with carfull design of seat and pedals.
posted on 16/11/06 at 10:52 AM Reply With Quote
pay attention to the pedal area - if you have large feet, then it can get quite tight in there even with ballet shoes
t.j.
posted on 16/11/06 at 05:42 PM Reply With Quote
I have small feet size 46
New Topic New Reply
