Author: Subject: Fuel proof rubber sheet
James
posted on 28/11/06 at 12:07 PM Reply With Quote
I need to make a gasket to seal between a 2" diameter hole in the top of my fuel tank and the plate that covers it that will be self-tapped on.
I've tried some rubbery Loctite stuff from a tube (that I was told was fuel proof) but it disolved into the fuel and blocked the filter.
I've tried some 'Red Fibre' gasket from Frosts but it's too 'hard' and doesn't seal properly.
I wanted to avoid Hermetite Blue as apparently it goes hard and bits can drop into tank and block filter.
The best thing would be a sheet of fuel proof rubber (similar to what's sealing my sender) but I can't find any for sale anywhere.
Otherwise a tube of 'goo' that is fuel proof but stays rubbery.
Please help! I'm getting desperate! The amount of fuel running out of my tank isn't good for my wallet, the environment, any bikers behind me, and the over-worked fire brigade in case I also drive over a still lit fag butt!
James
tks
posted on 28/11/06 at 12:12 PM Reply With Quote
mhhh
cant you just open up a fuel pipe? and drill and bend it? i used front wing kit/silicone / tube stuff and it works!
Tks
RazMan
posted on 28/11/06 at 12:19 PM Reply With Quote
It might be because the (I assume) fairly thin alloy is puckering between the self tappers. Have you tried a heavier gauge plate James?
Raz
Hammerhead
posted on 28/11/06 at 12:23 PM Reply With Quote
HI James,
I have a large sheet of rubber, approx 3mm thick. I don't know if its fuel proof but it seems very tough. Is it anygood to you? I can post you some if you u2u me.
CHeers.
Steven
posted on 28/11/06 at 01:28 PM Reply With Quote
I have a sheet of something at home that may help you - PM me with size and address and I'll pop a slice in the post.
I used it to make a gasket for my fuel sender, held in place with red hermatite (blue stuff is not petrol resistant) and no leaks so far.
Just to add I have used the plastic sheet from a milk carton before without problems
[Edited on 28/11/06 by 02GF74]
Dusty
posted on 28/11/06 at 01:36 PM Reply With Quote
You need nitrile rubber gasket sheet like this on fleabay. link
Dingz
posted on 28/11/06 at 02:03 PM Reply With Quote
Sorry Dusty James will need Viton for lead free fuels. If about 4" sq. is enough send me a U2U with your address and I will send some.
Dusty
posted on 28/11/06 at 05:00 PM Reply With Quote
Sucks. Is nitrile no good with lead free? What about all those nitrile O rings scattered about the car. I thought even the O rings on my injectors were nitrile. They should all be viton should they?
chriscook
posted on 28/11/06 at 06:47 PM Reply With Quote
I used a bit of inner tube on a blanking plate on the top of my tank. Seems ok but its not submerged being on the top face.
Chris
posted on 28/11/06 at 07:12 PM Reply With Quote
Don't know if you can still get it and if it would be OK with unleaded but Petropatch could be what you need . Put both sides of a piece of gasket paper it should seal
Dingz
posted on 28/11/06 at 07:33 PM Reply With Quote
Yes, sorry Dusty, stuff they put in the petrol to replace the dangerous? lead is very aggressive, bio fuels are as well.
If you need to replace any of the nitrile ones mail me with the sizes and I will see if I can help.
merkurman
posted on 29/11/06 at 03:16 AM Reply With Quote
I am using cork on the tank in my fairlane. I have the sender and pickup sunk in about 1" from the top and have no problems with it (my sender CAME with a cork gasket)
1962 fairlane with a 200" six and T5 5spd, shaved trim air ride, t3/t4 turbo and soon to be EFI
-- looking to put a offy tripower intake on soon
James
posted on 30/11/06 at 02:19 PM Reply With Quote
Thanks for all the responses and offers of help!
Richard has kindly sent me some rubbery sheet type stuff with which to make a gasket so I will fit this and see if I stop getting blocked filters and breaking down like this morning!
Thanks again,
James
[Edited on 30/11/06 by James]
