ROO
posted on 16/12/06 at 11:16 PM |
Which kit???
OK Im now confused. Originally I was going to build as the book says. Then I found out about the sierra donor with IRS. THEN I found out about
BEC's. Then there is +442's.
Right. Im 6'2. Ive got a 2.0 sierra. I want to build the chassis myself. I might be tempted by a BEC. Any suggestions?
Thang gue...
If it aint broke... fix it 'til it is!!
zxrlocost
posted on 16/12/06 at 11:22 PM |
basically this has been covered loads of times
do you want comfort with a windscreen reverse etc great performance
or do you want a RAW ballistic missile that does 60mph in first gear doesnt go backwards
does 13,000rpm sounds harmonic
paddle shift sequential gear box
blah blah blah
zxrlocost
posted on 16/12/06 at 11:23 PM |
ok locost with fireblade engine should do the job 6 2 is ok
donut
posted on 16/12/06 at 11:26 PM |
R1 !
zxrlocost
posted on 16/12/06 at 11:37 PM |
I was trying to do it locost for the guy
UncleFista
posted on 16/12/06 at 11:44 PM |
Thang gue...
The new book from Haynes is reputed to be out in February-ish [1].
It's based on a Sierra donor including IRS, although plans are already out there on the 'net for an IRS chassis[2].
[1] Anyone know anything for sure ?
[2] Not the same plans as the Haynes book, designed and researched by others.
Tony Bond / UncleFista
whitestu
posted on 17/12/06 at 09:51 AM |
I agree with Snoopy - well happy with my MK.
stu
omega 24 v6
posted on 17/12/06 at 09:58 AM |
There's a few of us building 442's and we all seem to be coming across the same problems.
If I was doing it again I'd go for a std book chassis as bodyparts are more available.
Get in touch with some of your local builders on here and have a seat in there cars. We all need time away from the build to have a natter
it's a very sociable hobby.
Danozeman
posted on 17/12/06 at 01:43 PM |
Youl fit in a book chassis. Im 6ft and i fit in mine and i dont have the seat right back.
As for the engine. If you already have a sierra id use that.
If i was building another id go mk or mnr.
Dan
