joscorstjens
posted on 17/12/06 at 01:34 AM |
engine stalls after first roar: need help
I just started up -for the first time- the pinto engine of my Tiger Cat . The injected engine (2.0 SOHC) runs for a couple of seconds and then stalls.
When working the throttle, I can make it run but if I hold the gas pedal steady, the engine will stall as well. What can I do to solve this problem?
The four exhaust tubes get hot just after a few startups. There is an occasional backfire if the gas pedal is pushed too hard.
I'm stuck.
tia for any help
jos
RazMan
posted on 17/12/06 at 08:36 AM |
It might be worth checking the fuel filter too.
Raz
omega 24 v6
posted on 17/12/06 at 10:00 AM |
If it runs OK by pumpimg thr throttle then check the TPS is working OK.
posted on 17/12/06 at 10:14 AM |
when my fuel pump died, i could keep the engine alive by pumping the throttle, holding it steady would kill it. Had to be frantic to even keep it
idling. What fuel pump and does it definately work? Is it still mechanical on the injected pinto? (id guess not)
[Edited on 17/12/06 by JoelP]
jimmyjoebob
posted on 17/12/06 at 10:21 AM |
Sounds like a fuel problem - enough in the line for the cold start valve to start it but not enough to keep it running. Check pump and filter
If at first you don't succeed, hide all evidence you ever tried!
froggy
posted on 17/12/06 at 11:00 AM |
i take it were talking about an efi pinto here ? first thing rig the fuel pump with a separate feed to see if it runs bypassing the relay if it does
then the pump relay is suspect,
cct7kitcars
posted on 17/12/06 at 11:09 AM |
nine times out of ten its the relay on these engines
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
CairB
posted on 17/12/06 at 11:51 AM |
If it's on standard injection then it sounds like it may be just firing on the afterstart enrichment, assuming it still sparks when it cuts out
which can be checked with a strobe light.
I'd check the connections to the Mass airflow meter and inlet temp, and the TPS pot.
IIRC all enrichments are done via the injectors.
Colin
joscorstjens
posted on 18/12/06 at 12:46 AM |
Thanks for all the inputs. In the mean time I found a hole in the air inlet tube, will fix that first.
