Author: Subject: to fit cat or not
thegasmen
posted on 27/12/06 at 03:05 PM Reply With Quote
to fit cat or not
The dax rush im building is a 98 carbed blackbird, will i need to fit a cat to it. speaking to the mot place today he says that you cant fit lamba sensors to a carbed motorcycle.And the lamba sensors control the amount of fuel to air ratio to stop damadging the cat.
anyone have any ideas.
regards mick
macnab
posted on 27/12/06 at 03:53 PM Reply With Quote
like wise I was under the impression (infact I know you can't) it's not possible to have a carb & a cat. You've got a big prob there...
Can you fit a more modern injection system to the engine???
[Edited on 27/12/06 by macnab]
DIY Si
posted on 27/12/06 at 04:03 PM Reply With Quote
The cat is an entirely stand alone device that can be fitted to any engine to reduce CO and hydrocarbon emissions. It can be fitted to carb's and FI engine. The lamda sensor is merely there to measure the O2 content of the exhaust gases (I think).
Also, the SVA and MOT emission level don't necessarily have anything to do with each other, as trhe SVA testes the age of the engine, the MOT to the age of the plate (or it should do before anyone says anything ), although some do find that the SCA limits get printed on the V5.
[Edited on 27/12/06 by DIY Si]
Sun Tzu, The Art of War
zxrlocost
Ok so
lets start from fresh any engine after 95 Bike or car, has to pass a cat test YOU WILL NOT PASS THE TEST WITHOUT A CAT that is certain on a bike engine
now my r1 carb engine didnt have a lamda sensor obviously
so therefore you have to adust the carbmixture screws LOTS of times(can be very fidly infact its a pissing pain in the ass and I cant believe Im aiming to do it again!!) to meet the required SVA requirements
forget what it does to the CAT thats the least of your worries
MY CAT system has been used on 7 BECs to get them through the SVA and hasnt failed them yet
[Edited on 27/12/06 by zxrlocost]
thegasmen
posted on 27/12/06 at 04:33 PM Reply With Quote
cat problem
Thanks fellas
when i rang sva in summer they told me it had to have a cat to pass sva so from what ive found out from the mechanic TODAY its going to shag the cat eventually and the car will run shite also,but he says that due to mot law the car will pass on the age of the doner car age which is 1991 sierra which doesnt need a cat. So does any body want to rent out there cat silencer for sva to be removed for a standard can when passed.BLOODY REDICULAS..
zxrlocost
posted on 27/12/06 at 04:57 PM Reply With Quote
hi mate
no one leaves the cat on after SVA
the cars dont need MOTING for three years anyway
your also most likely to get a Q plate so there is no emissions test after the SVA forever
I have one you can rent where abouts are you
ta chris
thegasmen
posted on 27/12/06 at 05:24 PM Reply With Quote
cat silencer
Hi Chris
Im up in leeds west yorkshire
Its not going to be for a while yet.
regards mick
DIY Si
posted on 27/12/06 at 05:32 PM Reply With Quote
Just actually seen you're running a "Bird. Mine must've had a CAT at some point (for the SVA), but certainly doesn't now, and passed it's MOT with flying colours. Only takes about 15-20 mins to do, so quick the bloke gave me a coffee so he had something to do for the other 20 mins!
Wadders
posted on 27/12/06 at 05:37 PM Reply With Quote
Iv'e got a full closed loop lambda air bleed system, and a cat welded to a standard gsxr can, which you can borrow for your sva. You'll have to adapt your existing exhaust to fit it though, and it needs a boss in the collector for the lambda sensor. I'm sure we can cobble something up.
Worked fine on my carbed ZX9. I live in Leeds 26 btw.
Al.
joscorstjens
posted on 28/12/06 at 11:40 PM Reply With Quote
Closed loop lambda? So which ECU are you using?
Bob C
posted on 28/12/06 at 11:54 PM Reply With Quote
You can get through SVA with a carbed bike engine and a cat - I did it last week. On a Q plate I should never need the cat again so I'll sell it on. With the cat on I got very low CO and HC but the lambda wandered about a bit, however I was able to pass.
If you're going for an age related plate and will need to pass emissions at MOT every year, it's probably worth investing in a closed loop system wth electrically operated air bleed valves as detailed on R Miles "strikerR1" website - and leaving it on.
Otherwise it looks like an unnecessary investment.
From memory it was called a "rent-a-cat" system, cost over a hundred GBP, and was obtained from "allbikes" ....???? It was a wee micro that looked at a lambda probe & clattered some air bleed valves to get the lambda right - you set the carbs up a bit rich.
Bob
