New Topic New Reply
Author: Subject: Bolt on roll bar
LBMEFM
posted on 1/1/07 at 02:27 PM Reply With Quote
Bolt on roll bar
How do I fit my bolt on roll bar? There does not appear to be enough room as the top bracket for the damper and other chassis tubes terminate on the underside of the mounting plate.
Thank you for your help.
goodguydrew
posted on 1/1/07 at 02:40 PM Reply With Quote
Good question, I was wondering that one myself. Do you drill and bolt through the square tubing?
mookaloid
posted on 1/1/07 at 02:42 PM Reply With Quote
As it is mainly cosmetic, most people use rivnuts.
If you want it to be safer then get one with backstays and have the whole thing welded on
Welcome by the way
Mark
[Edited on 1/1/07 by mookaloid]
Guinness
posted on 1/1/07 at 02:47 PM Reply With Quote
I drilled 4 holes through the mounting plate on the chassis and the plate on the bottom of the roll bar. The outer two had rivnuts in them, the inner two go straight through into the nuts with large washers to spread the load across the tubes.
I think that Indykid used 3 fixings though, two on the inside and one in the middle on the outer edge.
HTH
Mike
Bluemoon
posted on 1/1/07 at 03:12 PM Reply With Quote
I had the same problem. Best option is to get it welded on with back stays but to help with access I wanted mine removable.
After a lot of head sratching and thought I, and looking at how may bolts/grades westfeild had used I decided on 4 x 12.9 grade M8 cap heads on each side.
I found these are just small enough to lose the head inside the square tube, allowing you to bolt them up without crushing the tube. i.e. a large hole on the bottom to just allow the cap head to pass through the tube and 8mm holes on the top.
The nylon 12.9 nuts on the other side will be covered with SVA nut covers.
Their combined tensile strength of the 8 bolts works out about the same as westfields arrangement.
Dan
[Edited on 1/1/07 by Bluemoon]
Danozeman
posted on 1/1/07 at 04:11 PM Reply With Quote
I wondered the same. In the end i welded mine on. Easier to for me as ive got twin hoops.
Dan
kreb
posted on 1/1/07 at 06:47 PM Reply With Quote
Here are some pictures of a nice Yankee bolt-on.
http://www.teambirkinsport.com/gallery/hamlin
https://www.supercars.net/blog/wp-content/uploads/2016/04/1966_FiatAbarth_1000SP1.jpg
New Topic New Reply
