goodguydrew
| posted on 7/1/07 at 04:03 PM |
Side panel thickness
Can you tell me the thickness of sheet steel required for the side "bulkhead" at the driver / passengers outer elbows? It's the
panel at the front end of the trailing links.
Simon
| posted on 7/1/07 at 05:29 PM |
Andrew,
I don't have my book anymore, but all sheet steel on my car is 16swg (1.6mm).
Also - mines IRS.
HTH & ATB
Simon
DIY Si
| posted on 7/1/07 at 06:40 PM |
Do you mean the panel that sits right next to the trailing arm brackets or the outer "decorative" panels? If the trailing arm panel, 16
swg is fine, thicker if you wish a little extra support for the brackets.
Sun Tzu, The Art of War
Marcus
| posted on 7/1/07 at 07:03 PM |
I used a 40mm wide piece of 3mm steel to support the brackets and filled the rest in with 16 gauge.
Marcus
Because kits are for girls!!
| posted on 7/1/07 at 07:39 PM |
16 gauge on mine.
flak monkey
| posted on 7/1/07 at 07:43 PM |
If you mean this panel:
Then that and the bulkhead behind the seats in mine are 1mm ali. The floor is 1.5mm ali.
Sera
http://www.motosera.com
goodguydrew
| posted on 7/1/07 at 09:37 PM |
Thanks all,
I did mean "the panel that sits right next to the trailing arm brackets". 16 swg it is then.
