Author: Subject: which ford ecu for pinto with catalytic converter?
joscorstjens
posted on 9/1/07 at 11:11 PM Reply With Quote
I'm building a cat with an injected pinto. I'll need to install a catalytic converter for belgian emission tests. Apparently there were closed loop 'catalysed' pinto versions in germany in 1987/1988. So there must have been original Ford ECU's for this setup. Does anyone have a reference to these ECU's? I would assume that by swapping in any of these (or is it just a software upgrade??), I obtain a workable solution.
tia
