New Topic New Reply
Author: Subject: Hot or cold rolled steel
andrew-theasby
posted on 12/1/07 at 12:29 AM Reply With Quote
Hi, went to b+q to get ripped off for some steel the other day, and they were selling hot rolled (the black stuff, cheapest) and cold rolled steel box sections, just wondered what the difference was, ie properties, good or bad points. Ps, i chose the cold rolled (shiny) 1"x2" 1.5mm wall to weld in for my seat runners to mount on. This should be fine shouldnt it??
macnab
posted on 12/1/07 at 12:58 AM Reply With Quote
B&Q steel, great choice...
The oily almost shiny stuff is a rather brittle grade that will tare if folded too much. It's not nice really to work with and is best bent at red heat. The tubes will also come apart at the seams
The black stuff, hmm only work that at red heat also as that really tares. It is really best used to make gates.
As you may have guessed I have used both of their grades before and still have most if not practically all off it left. Do yourself a favour and take a visit to your nearest scrap steel merchant. There you will find all the steal pipe and plate you could ever want at a fraction that B&Q would have you pay.
just don't get me started about their bolts...
[Edited on 12/1/07 by macnab]
kb58
posted on 12/1/07 at 01:04 AM Reply With Quote
Cold-rolled steel, always. It doesn't have the nasty-to-remove scale on it.
This has been asked before, don't forget to use the search function.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
NS Dev
posted on 12/1/07 at 08:13 AM Reply With Quote
yep, cold rolled.
To be honest, on box section etc it makes little difference.
They are both made the same way, but one uses cold rolled sheet and the other hot rolled. To begin with both are hot rolled anyway, but the "cold rolled" is then cold rolled further to give a better structure to the steel and a better toleranced finer finish.
posted on 12/1/07 at 09:13 AM Reply With Quote
If you plan to bend the steel cold, you may find the hot-rolled 'black' steel more forgiving - the cold-rolled 'bright drawn mild steel' (BDMS) is very prone to cracking when bent cold. If you're prepared to bend it hot, either grade will do.
Note: this is for decent steel - not the rubbish that B&Q sell!
mcerd1
posted on 12/1/07 at 12:35 PM Reply With Quote
[Edited on 12/1/07 by mcerd1]
mcerd1
posted on 12/1/07 at 12:39 PM Reply With Quote
Hot is normalized - i.e. most of the stresses involved in bending and welding it have been releaved by heat treatment so its a little stronger
cold suffers from work hardening and residual stresses at the corners (which are also a larger raduis making it less stiff too) and you don't really want to weld anything to the corners of cold formed and so on
I'd go for hot (or seamless) but a much more important question is what grade is it - please don't say 'mild steel' - there are hundreds of kind of mild steel
in european structural grades (probibly what this is) there are 2 mild steels - brittish S275 and european S235 (the number is the strength)
high yield is S355 (or S460)
also diferent subgrades relating to its toughness (JR, J0, J2, K2 from worst to best - if it says nothing it means its total crap)
and then there is hot or cold
then you've got to get the right welding wire for your grade(s)
sorry, that sound a bit like a rant, but I spen half my time at work tring to get people to use the right grades
C10CoryM
posted on 12/1/07 at 03:02 PM Reply With Quote
Seems like ERW 1010 hot- rolled is what is readily available here in 1x1x16ga. Seems like it should weld/work just fine?? I'm new at fabricating so learning as I go. I can get pretty much anything other steel available, so long as I know what I need. I'm not sure seamless or DOM is available here though. Never seen it in square tube.
Still trying to figure out the aluminum specs too .
Cheers.
Cory
"Our watchword evermore shall be: The Maple Leaf Forever!"
quick n stuff
posted on 12/1/07 at 03:14 PM Reply With Quote
so am i right in saying i want bs s275 k2 hot rolled ??
mcerd1
posted on 12/1/07 at 03:27 PM Reply With Quote
no it would be: BS EN 10210 S275 J2H
i.e. Grade: S275, to: BS EN 10210, Sub Grade(or Quality): J2H
(the H doesn't mean hollow but it is for hollow sections - the BS EN 10210 is hot, BS EN 10219 is cold)
but that would be the standard stuff that most stock holder would have - not nessisaly what you need for a car chassis
sorry I can't be more help, I never went into all this (I bought my chassis) I can tell you about structural steel because that what I use at work (and what most stock holders have) but after that I don't have a clue
quick n stuff
posted on 12/1/07 at 03:38 PM Reply With Quote
thanks m8
andrew-theasby
posted on 13/1/07 at 06:56 PM Reply With Quote
thanks for the replys, and the advice on bending it. Shouldnt be too crucial this time, but ill know next time i need some and take your advice
New Topic New Reply
