cjtheman
posted on 12/1/07 at 03:53 PM |
pinto engined locost
hi all i have been told that to fit a pinto engine into a book chassis i would need to raise the height on the chassis dimensions by1" will this
cause any other problems like nose cone fittingany help please before i go too far
cheers
colin
macnab
posted on 12/1/07 at 03:55 PM |
first I've heard of it.
The sump will need a bit removed but thats all.
posted on 12/1/07 at 06:47 PM |
The Pinto is too tall for the "book" locost chassis and body work. Most cars designed to take the Pinto are approx. 1" taller to
accomodate it. even then you will probably still need to modify the rocker cover to re-position the oil filler neck to the rear of the rocker cover
to avoit it fouling on the nosecone and bonnet.
You will also need to modify the sump to reduce the depth or find an alloy RS2000 sump and pick up pipe (not cheap).
DIY Si
posted on 12/1/07 at 06:49 PM |
Taller body work is available, as it wider stuff to fit a +4 chassis. I believe the MK body work, as an example, is taller to fit a wider range of
engines.
Sun Tzu, The Art of War
gary gsx
posted on 12/1/07 at 08:36 PM |
Mines and book chassis with a pinto in it, im using luego locost body work ive modified rocker cover but going to fit a bulge to the bonnet mk one
more likely, i have seen them fitted with the cam wheel near the nose cone but ive put my back a bit more
caber
posted on 13/1/07 at 07:33 AM |
I am doing this too and just sorting the bodywork now. I am using a Caterham nosecone and it is about one and a half inches higher to clear the cam
wheel. I have done this by lifting the bottom of the nosecons on a bit of ally angle that will eventually have a hinge so I can flip the nose forward
for service access.
Regards
Caber
kj
posted on 13/1/07 at 09:35 AM |
I have a book chassis with a 1600 ohc, nose cone lifted slightly and engine on home made mounts using land rover rubbers and short sump.
The nose cone is about 5mm above the pulley.
Marcus
posted on 14/1/07 at 08:15 PM |
MK bodywork is the same dimensions as the book. The extra is in the chassis. GTS do taller bodywork ISTR.
Marcus
Because kits are for girls!!
