New Topic New Reply
Author: Subject: do you have to have a transmission tunnel thats so big??
goodall
posted on 22/1/07 at 07:04 PM Reply With Quote
goodall
posted on 22/1/07 at 07:14 PM Reply With Quote
oops forgot the body
surly all it need to be at the most is 6" so that the prop goes in there or does having it big give lots of strength
RazMan
posted on 22/1/07 at 09:10 PM Reply With Quote
Remember you have wiring loom, brake lines, handbrake etc. 6" is a tad on the large side but it depends on your prop, gearbox & engine measurements allowing for offsets too.
Raz
flak monkey
posted on 22/1/07 at 09:12 PM Reply With Quote
My one is 140mm wide across the inside of the tubes. Prop is a fiddle to get in and out, and its all quite tight. But it fits!
Sera
http://www.motosera.com
goodall
posted on 22/1/07 at 09:54 PM Reply With Quote
well it always looks very tall, maybe just looks big because the car is smallish
Johnmor
posted on 22/1/07 at 10:22 PM Reply With Quote
prop
Remember, depending on power output of the engine, this will determine the size of the uj joints on the prop.
If you go with more than 150 bhp you will need an uprated prop shaft that has a larger uj joint. My prop is in a 140mm tunnel and there aint much clearance.
Just a thought.
Marcus
posted on 22/1/07 at 10:31 PM Reply With Quote
Mine's even taller (by 1" ). This means I can get the gear lever remote inside with no unsightly connecting rods.
[Edited on 22/1/07 by Marcus]
Marcus
Because kits are for girls!!
Simon
posted on 22/1/07 at 10:42 PM Reply With Quote
Here's a pic of my tunnel (without the lid), you can calculate a vague idea of size (tubes are 1"sq).
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2004_0226Image0007.JPG
Simon
bartonp
posted on 23/1/07 at 11:51 AM Reply With Quote
Remember that if you have a live axle your prop goes up & down too (& prolly sideways a bit). The engine/box usually aren't solidly mounted either.
Phil.
New Topic New Reply
